Unread 10-03-2019, 07:55 AM   #1
Sdtile
Tools to set LEA slimtec panels
I have a job coming up that involves setting 6 slimtec panels for a patio backsplash. These panels will need a simple cross cut with some outlet cutouts. Each panel will ne8'2" long so it's a fairly simple cut for each one. I will need to buy all of the tools to install these panels. I've done some research and found that there are a few different manufacturers that make cutting and setting tools for these panels. I'm curious as to what you guys are using or wish you would have bought for tools. Also I'm debating on just building a table instead of buying one of these work tables. Any feed back is much appreciated.
Justin
Sdtile is offline   Reply With Quote
Unread 10-03-2019, 08:33 AM   #2
Sdtile
I should specify these panels are the 300cmx100cmx3mm.
Justin
SlimLite Panels? Vindly Tile Forum/Advice Board 2 01-28-2012 07:54 PM
Double OSB panels Bellsfloors Professionals' Hangout 19 01-04-2010 07:11 PM
Access panels Rich Turley Tile Forum/Advice Board 6 10-02-2005 10:05 PM
Dri-Core Panels fineline Tile Forum/Advice Board 6 05-01-2004 06:26 PM
