Unread 09-14-2019, 03:17 PM   #1
mike browning
Grout staining issues after clean and seal
Just had our ceramic tile floor cleaned and sealed by a "no residue" tile cleaning company. When the process was done and dry we noticed throughout the entire house areas where parts of the grout still appeared wet. Well it never dried and looks horrible. The cleaning company came back and recleaned a small section and removed the sealer and nothing changed. Then they used a product which removed a small sliver of the grout and still nothing changed. So it appears the stained section must extend through the entire section of the grout. Any ideas of what it is and how it can be rectified? If these stained sections of the grout are regrouted the colors will never match I fear.
mike browning is offline   Reply With Quote
Unread 09-16-2019, 09:29 AM   #2
Hi Mark,
I'm not sure which is the desired color, but if it's the darker gray I think there might be a little residue of something on the surface. In an out-of-the-way spot scratch the surface with an old screwdriver to see if the darker grout is just beneath the surface. If that's the case, I would recommend trying a mixture on 1:1 white vinegar and water. You'll need to scrub and then rinse thoroughly with clean water.
Best Products to Clean and Seal Shower Grout + Silicone Caulk AngelDIY Cleaning, Restoration and Sealing 4 06-25-2013 02:49 PM
How do you grout/seal/waterproof/moldproof/clean this?? djjasper Tile Forum/Advice Board 20 11-14-2011 09:32 PM
Best Way To Clean and Seal 15 year Old Grout PickleF16 Cleaning, Restoration and Sealing 7 08-11-2009 07:17 PM
Seal Grout Lines then Clean Haze from Slate? hurd Cleaning, Restoration and Sealing 1 03-01-2007 05:15 PM
Grout clean up issues!!!!! redlined7 Cleaning, Restoration and Sealing 3 10-25-2005 05:55 PM
