Unread 08-15-2019, 01:37 PM   #1
salbwil2
Cracked tile
Hi,
The first course of tiles directly above the tub flange on a three year old job have all cracked. These are 4x8 tiles and the cracks appear to be on the backs of the tiles and not all the way through. They are off white tile . The re is mold beginning between the tub and tile that cannot be removed ; I’ve tried everything. The tile is set on cement board painted with green redguard( if that makes sense). What to do here? Do I remove the tile and repaint with more green redguard and retile ?
Many thanks,
Salbwil
Salie
salbwil2 is offline   Reply With Quote
Unread 08-15-2019, 02:22 PM   #2
speed51133
Redgard is a specific name (trademark) for a product made by Custom Building Products. https://www.custombuildingproducts.c...-membrane.aspx
It only comes in dark pink and light pink, both of which dry to a deep red.
There are some companies that make a similar product that comes in green. Not sure it really matters which you have, but it is good to know.
Are you aware if the entire walls were coated with this stuff?? Are you aware of what KIND/brand of backer board was used??
Do you know how the tub flange was tied into the backer board and green waterproofing?
Do you know what kind of mortar was used?
Do you know if it was applied evenly or if globs were spot-bonded?
All questions that will help people make sense of this. Pictures also speak volumes.
Unread 08-15-2019, 02:28 PM   #3
Welcome back, Salie.
Is this perhaps a redo of a bath with which we were previously familiar?
Your chances of successfully removing the tiles without damaging the Hydro Ban are approaching zero if the tile were installed even close to correctly. That means the likelihood of your being able to repair the waterproof layer is very slim and at the worst possible place for that in your tub/shower installation.
Those stress fractures (what I think you're describing) are most likely the result of lack of movement accommodation in the wall(s) in question. Photos of what you've got might be helpful, but for certain we'll need more information on just how the shower was constructed, beginning at the wall studs.
Also helpful might be knowledge of the specific tile you have. Brand name, make and model.
Unread 10-16-2019, 10:06 AM   #4
salbwil2
. Pics are upside down, but show cracks .Will try to load some pics. Sorry to be so long gone....health and family issues. Tile is AO or equivalent. Thanks for the help in advance.
Sal
Salie
Unread 10-16-2019, 10:10 AM   #5
salbwil2
Also,
Studs, cement board , green guard , or what it is called and then tile. Tole setter was recommended by tile store
Sal
Salie
Unread 10-16-2019, 10:45 AM   #6
Lou_MA
My chances turned out pretty high, unfortunately. Maybe you could try same approach with kerf cuts, etc. https://www.johnbridge.com/vbulletin...d.php?t=126373
Lou
Cracked Slab Thus Cracked Tile Reginald Tile Forum/Advice Board 9 04-06-2017 06:35 PM
Cracked tile Hoskins Tile Forum/Advice Board 9 09-04-2007 06:14 PM
Cracked tile jackyga Tile Forum/Advice Board 4 09-04-2006 07:29 AM
cracked tile oggiem Tile Forum/Advice Board 1 05-16-2004 11:57 PM
Cracked Tile Simple Professionals' Hangout 25 01-09-2002 07:19 PM
