Unread 10-14-2019, 07:39 PM   #91
Lucy_Dawg
CX, so how would you build one for yourself? Where all would you caulk?
Paul
Lucy_Dawg is offline   Reply With Quote
Unread 10-14-2019, 08:43 PM   #92
Are you familiar with the Fifth Ammendment to the United States Constitution, Paul?
Unread 10-14-2019, 09:37 PM   #93
smifwal
Silicone your corners, use a profiling tool (I use these with great results https://www.homedepot.com/p/Cramer-F...AaAnCAEALw_wcB) or blue tape to get a consistent line and you should be able to hide that pesky inconsistency in your corner and silicone the change of planes
Unread 10-15-2019, 06:19 AM   #94
I siliconed all my wall to wall and wall to floor junctions, and where my corner benches abut the tile walls, Paul, and used the tape method to get clean straight lines with minimal clean up.
I have a niche placed low in a 40" high by 27" long wall. Technically a lot of plane changes but I grouted the whole thing.
Unread 10-16-2019, 08:06 PM   #95
Lucy_Dawg
Trying to cut some calacatta marble chair rail in mitered 45° cuts. This is going over like a fart in church. I get half way through cut, and it just crumbles. any advice?
Paul
Unread 10-22-2019, 01:12 PM   #96
Lucy_Dawg
How would you prep this outside corner, where the shower tile meets the sheetrock? If I lay a flat peice of wood on the sheetrock, you can see the small gap between the CBU and sheetrock, where corner should be. Should I just use a sheetorck metal corner? I thought I recall that you cant use certain metals near the thinset as the alkaline in the crete will mess up the metal? Any help is greatly aspprecated. Thanks in advance, to everyone!
Paul
Unread 10-22-2019, 08:06 PM   #97
I'd tape and thinset that corner square and run a row of tile up the outside wall. Looks like you already plan to run tile on the outside under the pony wall.
Unread 10-23-2019, 01:37 PM   #98
Lucy_Dawg
I planned to when I started the shower. Unfortunately, I cannot find any bullnose to match the tile. It is calacatta gold or Pietra, and the only companies I can find that make that tile in bullnose, the color of the bullnose is few shades of white off from the tile. The better half said no way, it clashes to much. I found some Calacatta marble, that matches closes enough, in Chair rail. However, I can only get it to cut straight without chipping. If I try to cut at 45º, the marble just crumbles. (I think it is cheap marble). I tried different blades, also. If you have any advice on cutting that marble, then please let me know.
So I was going to either use some schluter edging like Rondec, quadtec, etc Or do the Marble chair rail straight up the sides, but cannot make that 45º turn at the pony wall. I am laying 3cm Granite across the two tops of pony wall, and across threshold, so I could tie the straight cut marble chair rail into it. On the side with the funny corner, I could make granite pony wall top, run past corner and curve into wall, then run the chair rail straight off of that, similar to the way you trim a window/window seal.
Basically, have the granite cut like a stool, and have chair rail placed on that outside wall like the casing in image below. Thoughts?
Paul
Unread 10-23-2019, 04:40 PM   #99
With the tops of the pony wall(s) capped with granite, and then the CR set just below that, you're still going to need to cut some tricky returns for the CR. The stool and apron in that photo both have returns.
Unread 12-02-2019, 04:37 PM   #100
Lucy_Dawg
I had my granite cut and ready to install. Question is, how do I install, do I thinset it in, or do I use silicone caulk? For the pony wall caps, I don't think it really matters, but for the niche and bench seat, I am confused here. My initial thought was to set the niche granite, silicone the edges, then build over that, thinking it would keep water from getting under the granite. However, if I do this, a water gets in there anyways, will this not cause the water to be trapped between the granite and redguard? Same goes for Ben h seat. It I caulk around granite on 3 sides, this should create a barrier to prevent water from seeping in, however, water gonna do what water does, and will probably eventually find its way under there. If it does, surely I want to drain it, right? I mean, would it get stagnant, smelly, and mildew/mold? Would I be better to just thinset it, then grout around, to allow the water to easily move through there if needed.
Paul
Unread 12-02-2019, 08:20 PM   #101
Paul, I would set those pieces of granite the same as any large piece of ceramic tile. Get as close to 100 percent thinset mortar coverage on the back of the piece as possible. Treat the joints the same as you would the joints around any other tile you set.
Unread 12-04-2019, 12:22 PM   #102
Lucy_Dawg
How to cut soft/fragile marble trim pieces
I am having major problems with cutting some marble chair rail. I purchased at Lowe's. This stuff is super soft, and the edges just crumble. I have tried sharpening blade, went out and bought best blade from warehouse, I tried cutting dry, wet, tried a cut off wheel, a Dremel, I even tried freezing the darn things, which I must add, worked the best so far. I tried pushing through blade, pulling into backside blade, flipped them over, etc.. I am really at wits end here. I tiles the shower for these specific trim pieces, and am going to have to bust tile out and start over if I cannot get this figured out.
Using primarily a 10" wet saw with brand new blade. Best cut so far was on a frozen piece that way laid flat on a tile, pushed against fence, pushed through backside and pulled through frontside, then sanded with 400 grit. I have probably wasted about 15 pieces so far. Also, I can get it to cut perfect if a straight 90 cut, but when putting a 45 on it, the narrow corner just crumbles. I am wanting to picture frame a window with these, so I have to have 8 corner 45 cuts.
I have tried the, find some different material, didn't work. Went to about 10 different stores, couldn't find a match. Order samples from 5 different online store, didn't match. They don't make bullnose for my tile, so I am kind of S.O.L. if I don't figure this out.
Maybe a water jet? Is there some kind of trick I am missing? I even thought of freezing them in ice, then cutting the whole block and let water heat up and drop off? Maybe pour an epoxy over them until cut? HVLP them with a polycrylic? Anything is greatly appreciated. This is for the only person that matters, the wife, so I can't let this get the best of me. Got to figure out a way forward. Thanks in advance.
Paul
Unread 12-04-2019, 03:45 PM   #103
speed51133
what make and model saw are you using? what make and model blade are you using?
Unread 12-04-2019, 04:29 PM   #104
How 'bout a photo of what you're trying to cut, Paul.
Unread 12-04-2019, 07:28 PM   #105
Lucy_Dawg
This is the chair rail.
https://www.lowes.com/pd/Anatolia-Ti...-12-in/3510778
As for the saw, Its a chicago electric 2.5hp, and I have a Diamax Cyclone 10". The saw isnt the best brand, but it seems to cut porcelean tiles just gravy.
https://www.harborfreight.com/10-in-...saw-69275.html
Paul
Tile an old concrete foundation?? heyjude Tile Forum/Advice Board 4 03-08-2016 02:00 PM
Marble thickness-is a 5\16" thick 2" Carrara Hex over concrete subfloor thick enough? Babydoll66 Tile Forum/Advice Board 18 08-13-2015 04:43 PM
Tiling over concrete foundation stardog7 Tile Forum/Advice Board 5 11-13-2013 05:13 PM
How thick on that first slope? Fiddle1 Tile Forum/Advice Board 10 01-10-2008 09:15 AM
concrete foundation hef Tile Forum/Advice Board 9 03-24-2004 12:14 PM
