Unread 06-28-2019, 12:20 PM   #1
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Loose drop ears. Why and what's the fix
Hey all.
I posted this over at My buddy Terry's site but wanted to give you guys a crack at this. I have had my drop ears come loose on multiple showers. I never have had this problem prior to 3 years ago. What changed then you ask? I started using pex.
When installing I make sure to to level and square up the pipe coming out of the wall. Then a week later the fitting is wobbling. I mostly use kiln dried lumber. I am assuming the wood is shrinking.
So what's the fix? I want to continue running pex from valve to head. Thinking about getting a bunch of 6" square brass or bronze plates. Then brazing the drop ear to that, then screwing this plate to the blocking.
What are your thoughts?
Let's resist the urge to of saying not to use pex on the tub supply.
Vid showing issue
https://youtu.be/liehtB6JooQ
Travis
It's just a clever handle.
Unread 06-28-2019, 03:30 PM   #2
The plumber I use won't use Pex between the valve and shower head, he says that valve manufacturers don't recommend it because it restricts water flow.
That said, the Pex line is a lot less ridged than copper so it doesn't take much movement of the shower head/pipe to loosen the screws. Have you tried using 2- 2x4 blocks with longer screws?
How long are the screws you're using?
Unread 06-29-2019, 11:39 AM   #3
Just In Tile LLC
Just In Tile LLC's Avatar
I'd ask the same, what is your blocking and how is it being fastened. Then what screws are you using to fasten the drop ear?
I use 2x material and use 4 - 3-1/2" screws toe nailed in. For the actual drop-ear I use the 3 holes and also screw it down. No nails for my backing or attaching the drop-ear.
Justin
Unread 06-29-2019, 11:42 AM   #4
Tiger Mountain Tile Inc
I saw these cleats on a recent project. They seemed pretty sturdy to me.
Name:  2019-06-12 14.36.10.jpg
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 06-29-2019, 11:43 AM   #5
Just In Tile LLC
I'm liking those!
Justin
Unread 06-30-2019, 10:39 AM   #6
tilemanct
Tile & Stone
With the weight of shower heads today, most plumbers in my area use either a 3 hole drop ell or mount the two hole ell vertical instead of horizontal.
CTEF Certified Installer
Unread 07-02-2019, 09:16 AM   #7
speed51133
fill the wall cavity with a few cans of expanding foam. that will make the pipe solid
Unread 07-02-2019, 09:10 PM   #8
HS345
Tile Contractor
HS345's Avatar
I too wonder how you are fastening the drop ears. I honestly don't see how they can come loose if properly fastened. I've never had a call back, not that that means anything necessarily. All of the Pex drop ears I've used have three holes, and I usually use 1 5/8" cement board screws to fasten that to solidly fastened 2x material.
The name's Greg
Unread 07-03-2019, 07:22 AM   #9
speed51133
I have seen plumbers use nothing but a pex talon to secure a drop ear, or a single nail.
Some plumbers use these for a shower drop too. They are really flimsy...
Unread 07-17-2019, 07:42 PM   #10
Just In Tile LLC
Speaking of drop ears don't ever think you're smart and use one for a tub spout... don't ask me how I know.
Justin
Unread 07-17-2019, 09:13 PM   #11
smifwal
Same here, trying to reinvent the wheel, what a disaster that could have been
Unread 07-18-2019, 09:22 PM   #12
I've accessed the mounting screws by just removing the nipple and using a 6" driver. Can you do that on this?
Unread 07-19-2019, 07:40 AM   #13
wwhitney
So what's wrong with using a (non-PEX) drop ear 90 on a tub spout?
Wayne
Wayne
Unread 07-19-2019, 02:27 PM   #14
Just In Tile LLC
Not sure Wayne, I've never seen a non-PEX drop ear. I would think it would be fine.
I used a 1/2" PEX drop ear one time with galvanized nipple to thread my tub spout on. 3 screws solid as a rock! Then...at the END of my job I put all the plumbing on and ran the tub. Had water dribbling out the shower head (shower rise)and lower than normal pressure. After calling my plumber, wondering why this was happening, he asked about a drop ear.... I said yes. He went on to inform me he had also tried it one time thinking he was awesome, and how much smaller the ID of PEX restricted flow.
After tearing out the wall behind my shower and fixing it... I don't do that anymore.
Justin
Unread 07-19-2019, 02:44 PM   #15
While you can use pex to the showerhead, the outlet of the valve to the tub spout must be all full-diameter pipe. All of the instructions I've seen specifically call that out, but not everyone reads them!
IMHO, I'd never use galvanized there, either. It WILL start to rust eventually, leading to a rust stain. Either run copper and put a fitting on it if you want to thread on a spout, or use a brass nipple. The easier thing is probably to use one of the Delta spouts that can either screw onto a nipple, or an adapter soldered onto a copper pipe, then, the spout screws onto that adapter. It's much less fussy about getting things the exact length needed to get the spout tight against the wall and oriented properly than most other methods (except, probably a slip-on spout). A slip-on one is fine as long as you ensure you've cleaned up the end so you don't slice the O-ring slipping the spout on, creating a leak.
Bottom line, using pex anywhere to the tub spout in a tub/shower, is asking for problems...it will back up into the shower head unless you have a positive diverter in there...and, the smaller ID of pex means the tub will fill slower, too.
Drop-In Tub Install wolfeda16 Tile Forum/Advice Board 4 12-30-2016 09:25 PM
Obama's ears are growing. lasvegaslenny The Mud Box 11 09-01-2010 07:17 PM
dave m and brian got ur ears on opiethetileman The Mud Box 20 10-29-2009 09:14 PM
Drop in Tub handi Tile Forum/Advice Board 3 06-23-2009 03:30 PM
drop in tub gordonhoward Tile Forum/Advice Board 3 06-29-2004 12:40 AM
