Unread 08-04-2019, 05:31 PM   #31
I don't know how long pex has been around but seems like it's been 12-15 years ago when my old plumber used pex on two tubsurrounds that I had tiled. He had installed new valves in both tub surrounds. He talked about pex being a new product that he hadn't used very much. The homeowner complained to him about the water flow on those two tubs and I had to go back over there and bust out a groove from the valve to the shower head on both of them so he could replace the pex with copper. Of course the homeowner was pissed.
Like I mentioned before, the plumber I use now days says pex isn't recommended but maybe that's on certain valves, I don't know.
Unread 08-04-2019, 09:32 PM   #32
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Davy. There is truth to what you heard. I think the main concern is using pex on a tub spout on a tub/ shower setup. I have read not to do do in the instructions of a moen valve body. The reason being is that the possible restricted flow caused by the pex down to the tub spout can cause the water to back flow out the shower spout. That's how most are designed to do anyways. You know how you pull up the stopper on a tub spout and that diverts the water to the head. The manufacturers want copper down to the tub and either copper or pex to the head. I used copper to the tub spout in the bathroom that this thread was originally started for.
I wouldn't worry about using pex to a single shower head shower like in my recent picture. I use uponor pex and fittings and these allow for better flow. But I am in California where the legal flow rate is something like 0.2 gallons per hour so I have no worries of flow restriction, the state takes care of that for me.
Here is a tip and I am sure most of you know this. Install your valve upside down If you are installing a tub/shower valve is a shower only configuration. The tub side flow rate is much higher than your shower side. Especially if you are trying to do something with multi heads. I know moen valves greatly restrict flow to the shower.
Justin. Lol on the screws. Good catch on the screws. I am trying to make the switch to torx. These torx construction screws are better and not as brittle. These are what I used in the original post where the ear came loose. As for the 2 mismatched drywall screws. I had hung the lid earlier and this is what was on the ground and happen to match the bit I had in the drill. I don't know where that silver one came from but it got used. As got needing to switch between bits. Luckily the cordless took company that I use came out with an updated brushless drill that i had to have. So one's got the Phillips and the other has the torx. Surprisingly I still find myself switching bits.
Travis
It's just a clever handle.
Unread 08-05-2019, 05:21 AM   #33
Thanks, makes sense.
Unread 08-05-2019, 10:46 AM   #34
The reduced outlet for a shower is sufficient for one typical (legal) showerhead, but it would be useful to rotate the valve and use the larger tub spout outlet if using multiple heads. But, note that most 1/2" valves top out at around 5.5-6.5gpm, so more than two heads with a 1/2" valve will tend to start to show limitations, even with the larger outlet. FWIW, federal regulations call for NGT 2.5gpm at 60psi, if I remember correctly, so the smaller outlet is more than enough for one head.
Unread 08-30-2019, 10:11 PM   #35
Shady at Best
Tyrone shoelaces
This might clear up the pex to the shower head question. Looks like delta sells pex a rough ins with a pex attachment for the shower side.
Travis
Unread 08-31-2019, 08:27 PM   #36
Last december we installed that very same shower valve with pex. We had problems with the shower head always dripping when the water was flowing out the tub spout. Seems my choice of fittings increased the backpressure making the shower head drip all the time. Once I replaced the fittings the shower drip went away.
Luckily I installed an access panel and shut off valves.
Unread 08-31-2019, 09:29 PM   #37
This is how they do'em round these parts with a 1/2 a tube of silicone to hold the shower head in place. So I didn't get a picture of the silicone, I was in a bit of a hurry. It was a bundle. Travis I thought of you when I tore this one out and I shook my head and chuckled
Unread 09-01-2019, 09:53 AM   #38
I've heard this can also be a problem if the shower head isn't high enough above the tub spout. I like to drop the outlets down when installing an adjustable handheld but can't do it with the tub spouts that have the pull lever on the spout.
Jim Upton
Tiger Mountain Tile Inc is online now   Reply With Quote
Unread 09-02-2019, 07:11 PM   #39
I took one apart that was secured to a 2x with duct tape.
Unread 10-12-2019, 08:35 PM   #40
We've been doing it all wrong. Apparently it takes about a nickel's worth of hardware to secure these things.
Unread 10-12-2019, 08:43 PM   #41
Wait, those are drywall screws...not pipe screws!
Unread 10-12-2019, 09:10 PM   #42
The pipe screws are ten cents. Ya gotta draw the line somewhere.
Drop-In Tub Install wolfeda16 Tile Forum/Advice Board 4 12-30-2016 09:25 PM
Obama's ears are growing. lasvegaslenny The Mud Box 11 09-01-2010 07:17 PM
dave m and brian got ur ears on opiethetileman The Mud Box 20 10-29-2009 09:14 PM
Drop in Tub handi Tile Forum/Advice Board 3 06-23-2009 03:30 PM
drop in tub gordonhoward Tile Forum/Advice Board 3 06-29-2004 12:40 AM
