Unread 02-26-2017, 06:03 PM   #631
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Yeah. She sure looks nice.
Dewalt thinks of everything. I have had the pump fall off the tray of my mk while carrying it and swing around and hit my nuts. On more than one occasion. I hope it doesn't happen with the dewalt.
Sent from my SM-G935V using Tapatalk
Travis
It's just a clever handle.
Unread 02-26-2017, 08:44 PM   #632
Tiger Mountain Tile Inc
post 577
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 02-26-2017, 09:52 PM   #633
Shady at Best
Tyrone shoelaces
Thanks.
Travis
Unread 10-28-2017, 09:21 AM   #634
BimmerRacer
Not a pro
BimmerRacer's Avatar
Is there anything to do about this or do I need to replace?
-- Jason
BimmerRacer is offline   Reply With Quote
Unread 10-28-2017, 09:28 AM   #635
You can buy replacement parts here.
https://www.ereplacementparts.com/se...ewalt+tile+saw
Jim Upton
Unread 10-28-2017, 09:35 AM   #636
BimmerRacer
Not a pro
So thats the answer eh? Bummer, that's $150 for the three.
-- Jason
Unread 10-28-2017, 10:26 AM   #637
BimmerRacer
Not a pro
Seems like I am able to get most of the rust off with a steel wool pad so maybe I don't need to replace just yet
-- Jason
Unread 10-28-2017, 05:09 PM   #638
South land Tile
Spray a little wd40 on the rail run the cart back and forth vigorously and use it for another five years
Charles
South land Tile is offline   Reply With Quote
Unread 10-28-2017, 09:02 PM   #639
jondon
jondon's Avatar
posted by Jason:
I have a DeWalt boneyard, if I can get those rollers off the cart I will send
them to you or just send you the whole cart. Just pay shipping. Or maybe you got them cleaned up by now.
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 11-05-2017, 08:53 PM   #640
Yep, I keep a spray can of oil handy and oil my wheels just about every time I use my saw. Spraying them often makes a big difference.
Unread 05-20-2018, 11:20 AM   #641
Mr_Stop
Home Remodeler
Just picked up a new D24000 and going through the adjustments. The blade is really close to the right side of the 90 deg. groove in the table. Is this normal? There doesn't seem to be enough play in the adjust the blade into the center of the cutting groove.
Brad
Follow me on Instagram
Mr_Stop is offline   Reply With Quote
Unread 09-10-2018, 09:26 PM   #642
makethatkerdistick
DeWalt wet saw: problem with cart not centered
Hey experts. I did a thorough search but could not find my problem addressed anywhere. Hence I will start a new thread. If I have overlooked a possible solution discussed elsewhere, please point me to it. Many thanks.
My DeWalt saw has the following problem: The entire cart is positioned too far to the left with respect to the blade. The blade has ground off the paint on the right side of the notch for the straight cut. This currently works fine for straight cuts but if I were to use the notch for the 45 deg. and 22.5 deg. cuts, I would run into the cart's fence.
The entire cart would have to be positioned about an 1/8 in to the left. How can I do that? The saw actually cuts straight. The manual doesn't address this problem. I can adjust the stop screw for the miter cuts such that the blade is slightly backing off the notch. However, if I were to center the blade that way within the notch, it certainly wouldn't be true anymore, i.e. not sitting at a 90 deg. angle.
If my description is too cryptic, see the picture below.
Wolfgang
Unread 09-11-2018, 12:01 AM   #643
Combined you with an existing thread custom made for your post, Wolfgang.
You sure it's the saw table that's out of position and not your blade?
Unread 09-11-2018, 08:43 AM   #644
Topspin
SchluterUgrad
Topspin's Avatar
I have 2 DeWalts and on both of them you will see the blade has cut new grooves in the cart at the fence. Just happens. If it’s too far out of whack, if you have time you can take it to a DeWalt service center, but ours around here can take like two weeks to do anything. Otherwise start from the beginning and adjust your rails. Long is your machine is brand new It should be easier to do than an old one that would rather snap the bolt off than unscrew like mine.
Unread 09-11-2018, 07:31 PM   #645
makethatkerdistick
I aligned it again and lo and behold it has improved. It's still not centered but it is well clear of the notch. Aside from that, as topspin has pointed out, were it to cut into the cart's fence, it would really not be a problem.
Still, the stock blade is not good at all. It is WAY too flexible in itself for porcelain. Can't wait for my new T3 Razor to arrive. I hope that will bring up the DeWalt to its full potential.
Wolfgang
