Unread 11-22-2018, 09:19 PM   #3046
I use roofing nails but staples may work too. I run the head of the hammer along the edge of the stud to make a crease in the lath. It will tighten the lath and also set the lath back a little in the stud bay. This is especially helpful when you're trying to keep the scratch coat as thin as possible.
Unread 11-24-2018, 06:54 PM   #3047
jwmezzanotte
jwmezzanotte's Avatar
Hot new item from Laticrete (IMO)
Finally got my hands on some.
Hydroban quick cure
No need to wait to waterproof.
Floated yesterday, waterproofed today. Tile ready in 30min(ish)
jwmezzanotte is offline   Reply With Quote
Unread 11-24-2018, 06:57 PM   #3048
jwmezzanotte
I had three of those to float yesterday, only got two. Mixer broke down, some other issues ate up several hours.
Bleh! Can’t win them all.
I really wanted to get 3 ina day, would have been a record for me. Not meant to be this time.
Floated the third today while I did the waterproofing on the other two
Unread 11-24-2018, 09:18 PM   #3049
Looking sharp John, I saw Customs had a fast setting red guard too that was a no wait waterproofing.
Glad the products are being made for contractors timing and speed.
Unread 11-25-2018, 09:45 AM   #3050
Hydroban and RedGard are both great products. Just want to mention that Mapei has one also: Mapelastic™ AquaDefense dries in under an hour.
Unread 11-25-2018, 03:17 PM   #3051
jwmezzanotte
This isn’t Hydroban.
It’s Hydroban quick cure. It’s a new product that can be applied to mud as soon as it’s firm enough.
There’s no more need to wait for several days for the moisture to come out of the mud.
I’ve used lots of Hydroban in the past, this is a different product
Unread 11-25-2018, 03:26 PM   #3052
jwmezzanotte
Maybe I’m behind in my knowledge of the other brands.
Last I remember, going back a few years, all these liquid applied waterproofing products required several days of cure time over mud before being applied.
Maybe that’s not the case anymore?
Unread 11-25-2018, 05:51 PM   #3053
No I do think they have recently made a quick set version of their products that, like you've said can be applied to fresh mud. I saw a ad on the forum this year about the "rapid set red guard" read into it and it seemed great. Supposedly covered more with less product as well. Don't think I've seen a Mapei line of rapid waterproofing yet.
Unread 11-25-2018, 05:55 PM   #3054
Lou_MA
There’s Redgard Speedcoat, which is also pretty new. But it still calls for new concrete to have a day of curing at spec’d temp ranges. I don’t know if fat mud needs more / less time than concrete.
John - does Laticrete offer any input or guidelines as to the following:
“Over newly installed mortar beds, allow mortar bed to sufficiently set firm before application so that the top layer of the mortar bed is not damaged”
Does it have to withstand indentation by finger pressure? By point load? Withstand being abraded by a rub stone? Etc, etc.
Lou
Unread 11-27-2018, 08:45 PM   #3055
jwmezzanotte
I can’t speak for Laticrete obviously, but in my experience with the product it’s quite thick and sticky.
I’d prefer to wait until the next day to apply it.
If one was to roll the product over a fresh bed I think the roller would pull the mud apart.
They also came out with a rapid setting mortar bed for shower pans as well. I doubt I’ll use that personally, I’m happy enough with my own brew.
I believe using their rapid mortar bed and quick cure Hydroban you could in theory float a pan and waterproof/flood test it in a day.
I’d have to look into it more to be sure, but I believe that’s the idea.
Unread 12-06-2018, 08:30 PM   #3056
So this curious fellow had a previous memory come up today, and since I've remembered it for the whole day to ask on here I'm doing pretty good.
When I was coming up in the trade I remember a guy explain to me having to float out circular pillars. He explained something about some hose riding screeds up to cut the mud but I don't remember exactly. How would one float out a circular column or pillar? Semi circle plywood jig?
Which also reminds me, floating out porthole windows. Last time I saw one done was with a plywood jig....
Unread 12-07-2018, 07:54 AM   #3057
I advise all tile setters to get themselves to Coverings. It's the only place I know where you can get up close and personal to all the products mentioned here and a lot more. Most of the major setting materials companies are grouped fairly close together at the show. A couple days at the show will open your eyes.
Unread 12-07-2018, 10:42 AM   #3058
Justin, I can't ever remember mudding a column, only radius walls in showers. I would do it like you explained, run your sticks vertically and have a plywood jig on a half circle for cutting the mud.
On the first shower I did that had a half circle wall (many moons ago), I soaked my sticks and placed them horizontally. I cut a piece of 3/4 inch thick foam insulation board with the correct radius to set the sticks in the mud. Once set, I drove a nail at the end of the sticks to keep them from popping out. Then I run my straight edge vertically. Kind of a pain so since then I've cut the plywood jig.
Unread 12-07-2018, 06:28 PM   #3059
Dave Gobis
da Man!
Dave Gobis's Avatar
I did sticks and jig including some of those fancy bases. We use to make some crazy jigs just for fun, like a cornice. But, I was a lot younger.
Dave Gobis is online now   Reply With Quote
Unread 01-14-2019, 08:43 PM   #3060
Here’s one I find myself doing more and more. If you float the floor last this should work for you. The old school guys I apprenticed from would set screeds around the base of the shower for a tile ledge on float day, sometimes tile it same day, makes stacking the wall really nice and quick with some wedges to keep it perfecto.
I find this takes less time and gives me a nice start. I’ll take some topping mix and quick mix it in a bucket with a trowel and quickly and roughly put it at the base higher than I’ll need it. I’ll start tiling the wall with the bottom edge of tile on the topping mix, when I get my first couple rows up I’ll adjust the tiles to perfectly level by using my mallet on top. The mud is stiff enough to hold everything perfect. On some jobs I’ve moved the pile to the other walls as I stacked them, because the bond has set enough to hold the original wall by time I’m done. Gonna try with some damp sand one of these days and see if does the same effect to make cleanup easier at the end of the day.
mud work larrylou Professionals' Hangout 117 10-30-2011 02:33 PM
Where's that mud work how to thread? MGB Creative Tile Tile Forum/Advice Board 4 09-18-2008 05:26 PM
Mud work Rd Tile The Mud Box 2 04-16-2008 08:10 PM
Mud Work Charles P Professionals' Hangout 2 01-11-2008 07:33 PM
Methods for finding commercial work K_Tile Professionals' Hangout 23 10-31-2002 04:57 PM
