Unread 04-18-2010, 03:27 AM   #1
rollandelliott
$6 bag of Mortar + $5 gallon latex paint =$20 modified mortar?
My friend swears that instead of buying the $20 bag of modified mortar at lowes that if I simply mix a gallon of interior latex paint with the $6 bag of mortar and a little bit of water it is the same thing.
Anyone try this? I got a bunch of left over paint from a job.
Rolland
rollandelliott is offline   Reply With Quote
Unread 04-18-2010, 04:40 AM   #2
jondon
jondon's Avatar
Rolland,
Personally I leave the thinset making to the companies like Laticrete who do it for a living and have many years perfecting it. Why try to make it yourself when you can buy it already to go?
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 04-18-2010, 06:11 AM   #3
gueuzeman
Faux finish for your non-tile sheetrock walls.
Read the fine print- $6 a bag thinset is not good for much besides filler between your cementboard and the floor, the investment in tile and labor you will make is so much greater than what you will spend to buy a proper thinset. It's a big risk, and if you're willing to eat the job, possibly(probably), go for it.
Now excuse me, I need to go down in the basement and distill my own gasoline from some old paint thinner and some lawn fertilizer........
gueuzeman is offline   Reply With Quote
Unread 04-18-2010, 07:18 AM   #4
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Rolland,
I believe that your friend must be making a joke. Is this a friend with some chemistry background or a friend with some chemicals in his background?
Shaughnn
Unread 04-18-2010, 07:55 AM   #5
tilejoe
tilejoe's Avatar
I'll admit it, I have had this exact same thought...never would I do such a thing though.
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 04-18-2010, 08:01 AM   #6
Tell your Frankengueze-minded friend that you've decided you'd do a lot better adding some Elmer's White Glue to your sack of thinset mortar along with a little water.
Then y'all can have you a mortar-off, competing in various applications.
You'll win.
Well, so long as he don't run in no sure-nuff facory-modified mortars or manufacturer-recommended additive in place of his glue, of course.
Bet a lotta money on this. Share the proceeds with us.
Unread 04-18-2010, 08:34 AM   #7
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
Did he tell you this on April 1st?
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Unread 04-18-2010, 08:42 AM   #8
" Is this a friend with some chemistry background or a friend with some chemicals in his background? " Good one Shaughnn.
I do remember old timers adding Elmers glue like CX said. Although, I would leave it to the experts who have perfected it.
Unread 04-18-2010, 09:04 AM   #9
HS345
Tile Contractor
HS345's Avatar
It's not just the latex which sets the more expensive thinsets apart from the cheap ones, it's the Portland Cement content as well.
Leave the thinset chemistry to the experts.
The name's Greg
Unread 04-18-2010, 09:07 AM   #10
jerrymlr1
Way too funny. I laughed out loud after reading that one.
Jerry
Unread 04-18-2010, 10:11 AM   #11
Rkeister
Rkeister's Avatar
maybe he needs to shop around for his mortars.
If there are any tile shops in the area, he should be able to get better than 20$/bag. We sell grey sturdiflex for 12$ a bag.
-Ryan
Burlington, NJ Sales Rep
www.avaloncarpettile.com
Rkeister is offline   Reply With Quote
Unread 04-18-2010, 01:06 PM   #12
rollandelliott
ok what's the difference
ok, what's the difference between a $5 bag of unmodified mortar that takes 24hrs to set vs $13 bag modified that takes 24hs to set vs
$21 bag that takes 3 hours to set
I'm tiling a basement with concrete floors if that helps.
I guess what I'm asking is a totally newbie question but can I get away with the $5 bag for my application.
Rolland
Unread 04-18-2010, 01:11 PM   #13
HS345
Tile Contractor
HS345's Avatar
No.
The name's Greg
Unread 04-18-2010, 01:17 PM   #14
Splinter
Splinter's Avatar
The portland cement content of those $5 thinsets is pretty low... We dont recommend their use for anything but bedding some cement board, or yard bunnies.
There's many different types of modified, but something widely available like Versabond has an acceptable amount of portland in the mix, and the latex additive helps it stick better and cure properly.
The expensive quickset is expensive because it sets quick.
Alex
Unread 04-18-2010, 01:37 PM   #15
dhagin
Hi Roland,
That wheels already been invented. You're trying to make a better wheel...
...with a chemistry degree or 2, i'd say you have a fair chance after many failures and much money spent. Without the degrees, i'd say you have a very poor chance, after many more failures and much more money spent.
dana
Ardex GS-4: accepts latex-modified mortar? timo Tile Forum/Advice Board 2 02-28-2009 01:52 PM
HELP!! I have one bag of white mortar JGARCIA2000 Tile Forum/Advice Board 3 06-11-2006 08:09 PM
Need to mix less than 50lb. bag of Mortar Livens Tile Forum/Advice Board 15 12-28-2004 06:28 PM
Mortar with latex or lime? Ketch Tile Forum/Advice Board 3 06-26-2004 04:16 PM
latex modified thinset mortar Erich Tile Forum/Advice Board 2 12-12-2001 06:38 AM
