Old 11-09-2018, 10:50 AM   #1
rosietheriveter93
Americast Cambridge tub question
I guess this is more of a bath tub choice question. We're remodeling a guest bath and now that I've got some of the old cement and wire mesh with tile off the walls I've discovered that the "studs" against the cement block walls are actually more like 1x4s. A ledger board is required with the tub I'm looking at and the instructions say to use "roofing nails" to secure it to the studs above the ledger board. Would a 1 1/4 inch nail or screw be long enough (most of the videos I've seen use screws with a large washer)? We don't have the space to build out 2x4 stud walls or the tub would stick out past the door of the bathroom. Should I consider a different tub with built in supports on the base and set in some type of mortar - although they also have to be secured to the studs... From what I've seen most baths seem to have drawbacks, but Americast sounds sturdier than most of the acrylic tubs available.
Liz
rosietheriveter93 is offline   Reply With Quote
Old 11-09-2018, 02:41 PM   #2
Hi Liz, I'm not a big fan of acrylic tubs because they flex so much. Plumbers love them because they are light weight. But, I've tiled over many of them. Whichever tub you use, if possible you really want one that has a tub lip to tile over.
As far as the ledger board for the tub to rest on, you can drill thru the furring strips and into the concrete blocks and then use Tap-con screws.
Old 11-09-2018, 05:26 PM   #3
Raymond S
Carpenter - Tile Setter
Not a plumber by any stretch of the imagination, but we did install several Americast tubs after the flood here. After that, I bought two for myself. They seem to be a good tub. Pretty sturdy, coated steel, I think.
Like Davy said about the ledger board with tapcons
Raymond
Raymond S is offline   Reply With Quote
Old 11-09-2018, 07:18 PM   #4
Da Home Builder
Probably been ten years since I've handled one, but back in my building days I had good luck with the Americast tubs. Seemed pretty solid and I even installed one corner version with their proprietary add-on tiling flange and it worked out well. I recommend against such installations whenever possible, but the Americast version seemed useful.
May have dumbed them down in general by now, though, like so many other things.
Old 11-09-2018, 07:52 PM   #5
We recently tiled over 3 Americast tubs in one house, Cx. I'd say they are one of the better acrylic tubs made, maybe the best. I've found that acrylic tubs chip much easier than cast iron so we spend more time covering them.
I don't remember which brand acrylic tub it was on one job but it flexed so much that my silicone pulled loose within a couple weeks. No problems with cast iron, except to hear the plumbers cuss. Figured he would get over it.
Old 11-09-2018, 08:38 PM   #6
Raymond S
I do love the cast iron ones. Not moving them in or out,though.
Raymond
Set Americast tubs in mortar or no? - Wobbly new bathtub vwalton Tile Forum/Advice Board 38 08-03-2012 09:16 PM
Americast Tub Flange with Kerdi and 2" Tile Crazy J Tile Forum/Advice Board 9 09-22-2007 07:08 PM
Kholer Americast tub creaks Gregj236 Tile Forum/Advice Board 8 01-28-2007 04:54 PM
Cast Iron or Americast? jrizzo17 Tile Forum/Advice Board 16 04-21-2004 03:29 PM
Bathroom Remodel/Americast Tub johnnymac Tile Forum/Advice Board 8 07-17-2001 06:45 AM
