Unread 12-01-2019, 09:50 AM   #1
chilly81
Granite slab hearth spanning concrete and subfloor
For a wood stove installation, I'd like to put a 1.25"thick 25" deep granite slab over an existing 17" deep concrete hearth extension base. The extra 8" of depth will extend over a 3/4" plywood subfloor. The subfloor surface is roughly 3/16" lower than the concrete. It is sturdy and well framed below. The slab will be the same width as the concrete (55").
Would it be adequate to simply put down a layer of thinset on the concrete, and a significantly thicker layer on the subfloor to make up the 3/16" gap... assuming I put a couple hard points/shims there so it wouldn't 'sink' and force the thinset out and become unlevel before it has a chance to harden?
Would appreciate any advice or alternatives (short of reframing and repouring the concrete - it would be invasive of a project underneath)... or specific details of what to use (type of thinset etc).
Attached a picture (prior to cutting back the flooring in front, but showing one peice of flooring removed to the side to show the subfloor).
Much obliged!
chilly
chilly81 is offline   Reply With Quote
Unread 12-01-2019, 10:51 AM   #2
So, I assume you still have to remove some of the hardwood. I would use filler to fill the lower area to get the whole surface flat. Once it's set, stick the whole thing with thinset.
Unread 12-01-2019, 07:25 PM   #3
chilly81
Yes that's right - just haven't removed the flooring yet in the pic. What would you use specifically for a filler? Does thinset not act as a filler itself, or would you use some thicker type of mortar?
chilly
Unread 12-01-2019, 11:10 PM   #4
The problem with using thinset mortar is shrinkage. It will shrink more in the deep areas. So, if you filled everything in one shot so that it was perfectly flat across everything and you dropped the slab on it, the thicker areas shrink more than the rest and you’d lose support in those areas.
There are plenty of floor patching compounds that would work well. Fill the deep areas to get everything flat. Then use a modified thinset mortar of your choice to set the slab.
Granite Slab Hearth The stump Tile Forum/Advice Board 8 01-15-2017 05:26 PM
granite slab/hearth extension JNelson Tile Forum/Advice Board 5 03-30-2016 03:27 PM
Granite Slab Hearth - Simple, right? DYI Steve Tile Forum/Advice Board 15 08-03-2013 12:09 PM
Question.. Granite hearth to concrete slab shtojo Tile Forum/Advice Board 2 04-06-2010 12:47 PM
Slab granite hearth & surround MajMetro Tile Forum/Advice Board 2 07-14-2006 08:07 PM
