Unread 11-26-2019, 10:10 AM   #1
Old_Smokey
Advice for backer issues found after Redgard applied
Hi everyone,
Been reading this forum for weeks straight as I'm in the middle of my first bathroom renovation and tile project. I had a Bathfitter style tub and surround that failed so I decided to gut the lot and start fresh. My house is from 1938 in the Canadian prairies, so it's not flat, level, or square, and is subject to some real temperature swings!
My plan was to use Wonderboard Lite 1/2" on the walls, followed by Redgard then subway tile. On the floor I used 3/4" plywood screwed through the old planks and joists, thinset and 1/4" Wonderboard Lite, followed with 7" hexagon tiles from AMES.
The tub is a MAAX Bosca unit, installed in a bed of mortar.
Here's my challenge - I spent a ton of time shimming and sistering studs to get my walls flat to within 1/16". I have a window in the 5' wall, and a small niche in the wall opposite the tub controls.
I taped and thinset all the joints and seams a few days before applying Redgard. Someone how I missed a 1/8" bulge at the lower right corner of my window. Looking through my pictures, the backboard looks to have been cut and installed correctly, so it must be a bulge of thinset and tape. Now it's covered in Redgard. This is going to cause a real ugly issue when laying the tile...
I found some cracking in the corners of my Redgard anyway, from over application. What's my best option here? Cut the Redgard back and grind that thinset flat? Float the thinset out around it to hide it? It's white 3x6 tile with black 1/8" grout lines.
The floor went in ok. I have one bad tile that needs to be replaced. And two or three spots with maybe 1/16" lippage. I'd say an 8/10 job. Not the worst for my first time ever, but I had hoped for better
Mark
Old_Smokey is offline   Reply With Quote
Unread 11-26-2019, 10:19 AM   #2
Old_Smokey
Some progress images just for context.
Mark
Unread 11-26-2019, 11:30 AM   #3
speed51133
just shave it down with any tool. Rasp, grinder, chisel, etc.
Then re-apply tape and thinset to patch it and re apply redgard overlapping the existing redgard.
as to the cracks, do not gob it on. just paint a thin coat, let it dry, then another thin coat, let it dry, and one more if you want.
Unread 11-26-2019, 11:31 AM   #4
Welcome to the forum, Mark.
I would use a scraper with a razor blade and aggressively shave that bump off the wall. Then fill any gaps with mortar, let it dry, and reapply Redgard. You want that wall really flat for those subway tiles.
Did you use mesh tape and mortar on all the board seams?
Unread 11-26-2019, 11:45 AM   #5
What the others said, grind it down and apply more Redgard. I would get all that Redgard off the window, it'll be easier now then after you tile it. Of course it would have been easier to clean when it was wet. If you're not, keep a bucket of water and sponge handy.
Unread 11-26-2019, 12:06 PM   #6
Old_Smokey
Thanks guys. I’ll trim back the redgard and use a diamond grinding wheel to get that flat.
I used 2” mesh tape and thinset on every seam and corner. I’m thinking that tape didn’t lay flat or something and I didn’t catch it. I’ll get things flat again and reapply the redgard, overlapping a couple inches afterward.
I was feeling real bad about this but now I have a plan
Mark
Unread 11-26-2019, 12:23 PM   #7
Once the Redgard is dry, you can apply a thin coat of thinset with a wide putty knife or flat trowel around the window. After it sets, go over it lightly with sand paper or rub stone to knock down any ridges or humps. Like Kevin said, the flatter you get the walls, the easier the tiling will be.
Unread 11-26-2019, 12:33 PM   #8
Old_Smokey
Davy, are you suggesting to remove old redgard, grind down the hump, reapply redgard, then float around the window (over new dried redgard) with a thin layer of thinset?
Mark
Unread 11-26-2019, 04:55 PM   #9
Yes, nothing wrong with doing that as long as its thin, say 1/8 or less.
Unread 11-26-2019, 04:57 PM   #10
Old_Smokey
Wonderful. I like that idea, should really hide and blend in these little mistakes. I’ll post some results when I’m finished.
Mark
Unread 11-26-2019, 05:00 PM   #11
Of course the wider the putty knife or trowel is, the more gradual it will be.
Unread 11-26-2019, 06:55 PM   #12
Old_Smokey
Peeled off the Redgard. Some places were really hard to remove, others came off a bit easier than I expected but not like it was nothin. I took the grinder to all the high spots. It was mostly excess thinset, and one spot where kerdifix oozed out. I’ve got the entire window perimeter to within about 1/8” of the rest of the wall. I’m going to float a later of thinset with my 12” knife and blend it in. I should be good to tile after that.
Mark
Unread 11-26-2019, 06:58 PM   #13
speed51133
Why is there kerdi fix there???????
Unread 11-26-2019, 07:05 PM   #14
Old_Smokey
I used a bit of kerdifix between the window vinyl frame and the back of the cement boards that makeup the window sill and jams. Not to bond the boards together or anything. It was just to act as a secondary waterproofing between the cement board and window. Looks like a bit oozed out.
Mark
Unread 12-01-2019, 05:26 PM   #15
Old_Smokey
Urgent advice needed!
Hi everyone,
I'm almost finished tiling my surround and hit a snag.
I tiled around my niche using bullnose tiles and have a snag. I framed it 1/8" too short. So my grout lines match everywhere expect at the top where I have a double width, 1/4 grout line. It just screams out as this is white subway tile, black grout.
What can I do here to fix this? My only thought was sandwich one or two pieces of 1/2 cement board to bring the 'top' down and make it look deliberate.
I tried shaving a tile down a bit, but they're only 1/4" so there isn't much left.
Also the top ledge tapers from left downward to the right a bit.
Mark
Found few small issues while re-caulking tub junkelly Tile Forum/Advice Board 3 01-08-2018 11:56 PM
Hello, happy I found this place, stone shower floor advice CFinn Tile Forum/Advice Board 45 10-01-2017 05:52 PM
mapei ultracolor plus. Installer Issues. I need advice bjl95mustang Tile Forum/Advice Board 10 07-02-2015 10:14 PM
Professional advice needed! Redgard over CBU Newbie88 Tile Forum/Advice Board 2 08-02-2006 06:45 PM
Shower niche advice (and probably other issues) flash12b6 Tile Forum/Advice Board 2 03-27-2006 07:37 AM
