Unread 08-04-2019, 05:24 AM   #91
Karls tile Inc
I will sometimes template the backsplash. Then layout all the tile on the floor and overlay the template. Precut the whole backsplash and then install it.
Karl
Karlstile.com
Unread 08-04-2019, 12:41 PM   #92
Karl, what do you make the template out of?
Unread 08-04-2019, 06:45 PM   #93
Karls tile Inc
Strips of luan plywood about 1/4 thick hot glue them together. Pretty much like how counter top guys template. I have also used large pieces of cardboard.
Karl
Karlstile.com
Unread 08-04-2019, 07:28 PM   #94
I was thinking you might use 1/4 inch luan and hot glue.
Unread 08-04-2019, 08:41 PM   #95
CaliGrown
CaliGrown's Avatar
Mixer tips
One handed mixing or free-handed if you have the button lock and can move your hips to dance with the mixer. And a nice spot for mixer storage under the saw. DeWalt didn’t pay me, I paid them a while back.
Rest In Peace Joey Peres (7/16/95 - 8/31/19). A great friend and the best helper I’ve had.
Unread 08-10-2019, 10:31 AM   #96
One-handed mixing is important these days because it allows you to hold a camera in the other hand.
I like the storage idea. I usually hang my trowels on the cross bar going the other direction
Jim Upton
DIYTileGuy
Unread 08-18-2019, 10:23 AM   #97
CaliGrown
CaliGrown's Avatar
Haha. Thanks now all my trowels have a home outside of the bucket bin. Here’s a simple, “niche wedge” I do the same for accent band spacers.
Unread 08-18-2019, 12:58 PM   #98
like this
Unread 08-18-2019, 02:45 PM   #99
CaliGrown
CaliGrown's Avatar
Yep ‘xactly like that. Best way
Unread 08-19-2019, 12:10 PM   #100
Canvasback Construction
Small tip that I've worked out but it's saved me a ton of headache-I cut aluminum Schluter trim with a Dremel Ultrasaw, it works great but can leave a line of aluminum flashing sticking up from the cut. I used to use some sandpaper to rub it off but you always risk scratching the trim, I hit on the idea of using the back of a tile offcut to rub the cut line, it works like a charm to remove the cutting flash and unless you really get after it it won't scratch the trim. It's been a real time saver!
Cody
Canvasback Construction is offline   Reply With Quote
Unread 09-03-2019, 11:11 PM   #101
CaliGrown
CaliGrown's Avatar
Night time or early morning tile cuts.
Unread 09-28-2019, 06:10 PM   #102
I taught this to a tile guy years ago. I thought it might help someone here.
Whenever putting carpet back to tile. If you are using a kicker make relief cuts before you kick it up on the tackstrip. If you have a power stretcher ( you might already know this) you can make the relief after you make the stretches before you trim the carpet
This is the what I got when I tried to up load the photos
Unread 09-28-2019, 08:31 PM   #103
Went back and tried again all is well
Unread 10-06-2019, 02:57 PM   #104
Sdtile
I use a carwash ringer for my grout sponges. Fast, easy and just the right amount of moisture in the sponge.
Sdtile is offline   Reply With Quote
Unread 10-23-2019, 09:35 AM   #105
CaliGrown
CaliGrown's Avatar
Level storage, magnetic levels aren’t as dumb as I thought.
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
