Unread 08-12-2009, 03:59 PM   #46
scuttlebuttrp
Richie,
They're mixing the 4237 into the grout and using that mixture as the pooky and grout.
ie. it's grout holding the tile to the wall.
Royce
Unread 08-12-2009, 04:05 PM   #47
Tim,
your paying too much for 254.... sorry for being i get mine for 38 something a bag white
Unread 08-12-2009, 04:07 PM   #48
Rd Tile
Tile Man
Rd Tile's Avatar
I understand that, just that I never used the same mix for grouting, always came back with the same color grout with 1776.
Richie.
Unread 08-12-2009, 04:11 PM   #49
scuttlebuttrp
Richie,
No need. If your using "Latte" grout. Mix 4237 into the Latte, notch the Latte on the wall, fill joints with the same stuff, stick to wall. That's why it's called one step.
Royce
Unread 08-12-2009, 09:51 PM   #50
gueuzeman
One step- puill your paper and fill any voids you have with more of the same you already have mixed. Done.
Richie- watch the video, lol.
http://www.youtube.com/watch?v=0Uajp9j2Uc4
gueuzeman is offline   Reply With Quote
Unread 08-12-2009, 09:52 PM   #51
gueuzeman
Also- Tom- on watching my video again, I guess I didn't need to knock down the ridges as I used a Frankengueuze custom trowel!
Unread 08-20-2009, 06:57 PM   #52
Creato
I'm going to chime in here. I just completed day two of a glass mosaic backsplash using the One Step Method. While I agree it might be simpler, I find the working time with 1500 and 4237 minimal.
After letting it set up to a point where I can take the paper off, the grout has hardened enough where it isn't hardly workable any longer to smooth out joints.
Maybe I'm a little more finicky about the grout, but I like consistent smooth joints and I can't seem to obtain that with this method??
Joe
Creato is offline   Reply With Quote
Unread 08-21-2009, 10:42 PM   #53
hbrothberg
hbrothberg's Avatar
Smooth, Full, Flush grout goints ....! Yes, Please.
So Joe Sez:
"After letting it set up to a point where I can take the paper off, the grout has hardened enough where it isn't hardly workable any longer to smooth out joints."
And I say ....
Sounds like a simple timing issue .... We DO want smooth, full, flush grout joints with this method...!
Joe ... can we chat ..?
May I call you ..? Would you please PM me with your cell phone # or call me ..? My cell phone number is below.
Henry
Henry Rothberg
hbrothberg@laticrete.com
www.laticrete.com
Office: (203) 393-0010 ext 202
Cell: (203) 988-1814
Full Disclosure: I am a 2nd generation Laticrete guy !
Follow my Blog: www.laticrete.blogspot.com
hbrothberg is offline   Reply With Quote
Unread 08-21-2009, 10:56 PM   #54
Henry........
Unread 08-22-2009, 07:35 AM   #55
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
Have to agree with Henry about it might be a timing issue, try removing the paper a little sooner and then gently wipe down your walls.
Brian, no time for fishing, get back to work.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Unread 08-22-2009, 08:47 AM   #56
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I don't see this method being for a backsplash with all the oulets to cut around. As well as the cabinet shape to deal with. Seems like it would be sweet for nice big open walls. Can't wait to try it out.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 08-22-2009, 09:00 AM   #57
Chad,
Definatly sweet for open walls, and if you have a helper to butter the mosaic for you , you can really move fast and no coming back to grout.
Steve
Unread 08-22-2009, 12:20 PM   #58
T_Hulse
Tile Contractor
T_Hulse's Avatar
Joe I think you can take the paper off much earlier than you think. If it's wet down enough to where the water has fully penetrated the glue, then the paper will practically fall off the wall. So it's exerting almost no pull-out pressure on your fresh-set pieces if you're careful. You still want lots of time to move them around to adjust the grout lines after you pull the paper.
I then go back just a little later, after it's hardened a little more, and overgrout to smooth it out.
Chad I bet you'll love it for backsplashes with outlets once you get used to the method and have a solid feel for timing & how much to do at once. Honestly I now look forward to paper-faced glass more than mesh-backed.
Tom Hulse
Visit my web site here
Unread 08-22-2009, 12:54 PM   #59
Got to agree with you Tom, i love the paper faced glass as well.
Steve
Unread 08-22-2009, 12:58 PM   #60
Creato
So, am I safe to say that once the tile is set I can go ahead and begin wetting the paper and removing? I was setting the tile, waiting maybe 10-15 minutes then beginning the wetting process.
I also noticed that the grout protrudes slightly above the tile surface. I've been leaving it that way as the minute I start to level it out with a sponge it starts to fall apart on me. Even with this, the grout joint surface is very inconsistent-- not smooth.
Possibly all these problems are due to me waiting a bit too long?? Problem is, if you go to quickly, your tile isn't completely set, and there's possible movement. Rubbing lightly doesn't really do the trick.
Maybe it's all a conspiracy, and Laticrete is trying to have me committed!
Joe
One step method John Dumbrille Professionals' Hangout 26 01-16-2010 07:14 AM
Glass mosaic over kerdi - One Step Method? tzalud Tile Forum/Advice Board 1 02-29-2008 10:44 AM
Best tool or method for cutting glass tile? kwh9 Tile Forum/Advice Board 3 12-06-2007 06:11 PM
Best Application Method for 1" Hex Mosaic Floor Tile. CalBear Tile Forum/Advice Board 9 09-03-2004 12:24 PM
Best Method for Cutting 1" Hex Mosaic CalBear Tile Forum/Advice Board 8 08-11-2004 04:36 PM
