Unread 02-24-2020, 09:08 PM   #16
Well, I just saw the cut piece there, so I'll change my advice, and my optometrist.
Yeah, break it out as previously mentioned and replace it.
Unread 02-26-2020, 11:51 AM   #17
sonofarnold
Thanks for your recommendations. I will attempt to remove the tile. I will start with the middle shelf one as that is only like a 2" tile as opposed to the other two that have a 5" tile. That way I can reevaluate after the first one to see if it is worth continuing on the other two.
Nick
sonofarnold is offline   Reply With Quote
Unread 02-29-2020, 02:22 PM   #18
sonofarnold
I don't have anymore hydro ban and can't get anymore for a few days. Can I get the red gard or mapei aqua defense from home Depot or Lowe's to patch the little hole? Will it play nice with the hydro ban ? It looks like mapei and hydro ban have same ingredients according to SDS info....zinc oxide and titanium dioxide.
Nick
Unread 02-29-2020, 07:32 PM   #19
jerrymlr1
I think it will work. I wouldn't think twice about just leaving it as is either. The amount of water migration you'll have in that area of the shower for the next hundred years, as far as can tell, won't cause any problems with that little ol bitty area of hardi not waterproofed.
Jerry
jerrymlr1 is online now   Reply With Quote
Unread 03-01-2020, 10:25 AM   #20
sonofarnold
Very tedious...I used a punch to crack tile and then used a tiny chisel to peck away at the layer of thinset in between the tile and waterproofing membrane. Mostly good definitely some tears in the waterproofing that I took a razor knife and scored clean lines to maybe give new waterproofing membrane something to bond to. Thinset had a very good bond to tile and waterproofing.
Nick
Unread 03-01-2020, 12:51 PM   #21
jerrymlr1
Yes, tedious, but worth the effort. Nice job!
Jerry
Unread 03-14-2020, 09:46 AM   #22
sonofarnold
Tile and grout is complete. I caulked corners and shelf with TEC matching standard white silicone caulk to go with the powergrout 550 standard white I used. It has been 48 hrs and still looks really dark and more grey. Anyone else have problems with color not matching for TEC products. I used GE silicone in between the tub and tile because that will match good with tub.
Nick
Unread 03-14-2020, 10:49 AM   #23
sonofarnold
Better pic
Nick
Unread 03-14-2020, 10:55 AM   #24
jerrymlr1
That's a bummer Nick. Otherwise your job is A game. That's why I just grout and don't caulk. I prefer to chance a minor crack vs a racing stripe.
Jerry
Unread 03-14-2020, 01:07 PM   #25
Same as Jerry, I grout that joint.
Unread 03-14-2020, 01:26 PM   #26
Yep, I always grout that around the dish.
Unread 03-15-2020, 03:57 PM   #27
sonofarnold
Grout it is thanks guys.. A walnut pick comes in handy to get the caulk out
Nick
Installing Corner shelf hiestrun Tile Forum/Advice Board 3 08-29-2012 05:44 AM
Corner shelf Mummy Tile Forum/Advice Board 6 09-21-2011 01:46 AM
Corner Shelf & Better Bench jfonta77 Tile Forum/Advice Board 8 04-16-2011 05:22 PM
Corner Shelf ctoad Tile Forum/Advice Board 2 10-09-2004 01:42 PM
Another corner shelf gable74 Tile Forum/Advice Board 4 07-13-2004 11:45 AM
