Unread 02-22-2020, 11:19 AM   #1
fordperson
quick tile question
I am working on another shower. I am using aprox 1x1 hex tile around the shower drain and managed to set a single tile slightly (1/32) above the drain. I take it this is going to be a problem? what is the best way of taking it out?
Tom
Tom
fordperson is offline   Reply With Quote
Unread 02-22-2020, 11:24 AM   #2
Below the drain would be a problem, above the drain is not a functional problem and if it's not an aesthetic problem I'd leave it alone.
Without knowing how your shower receptor was constructed, it's not possible to tell you how problematic removal and replacement might be.
Unread 02-22-2020, 11:42 AM   #3
fordperson
here is some pictures. its a kerdi drain. I was thinking of cutting the tile with an angle grinder and just chiseling it out.
Tom
Unread 02-22-2020, 02:12 PM   #4
You said it's a Kerdi drain. Is there Kerdi under the tiles? If there's Kerdi or other surface applied membrane under the tile then I'd leave it alone. You'll be opening a can of worms if you damage the membrane.
A lot also depends on how long the tiles have been installed. If they were set yesterday then the thinset is probably wet enough to let go without damaging the membrane. But, I can't promise that.
Unread 02-22-2020, 03:45 PM   #5
fordperson
yep there is kerdi under there, Im going to try to just grind out the small piece using a diamond attachment and replace it. This tile is quite thin and the area around the drain flange shouldnt have kerdi under it. wish me luck
Tom
Unread 02-22-2020, 03:46 PM   #6
fordperson
BTW how big of a deal is this? i know its not perfect but i wonder if its livable..
sorry I just noticed I made a mistake in my original post, the drain is actually higher then 2 of the tile pieces and not the other way around.
Tom
Unread 02-22-2020, 06:04 PM   #7
PC7060
PC7060's Avatar
From the pictures it does not appear to be a big deal to me but you are the final judge. When facing similar dilemmas I often find if I give it a bit of time it becomes apparent the problem really isn't a problem and gets categorized as "fine as is".
Davy's "opening can of worms" is a apt description of what could happen if you try to remedy it.
Unread 02-22-2020, 06:32 PM   #8
Originally Posted by Tom
quick tile question
Best you stop doing that "quick tile," Tom. If you slow down just a bit you might find you end up with fewer of those afterthought problems.
Unread 02-22-2020, 06:41 PM   #9
fordperson
haha yes i should.
Well to give you guys an update, I was able to remove the tiles in question with a center punch. I started at the edge of the tile and slowly chipped it away.
Should be all good thanks all.
Tom
Unread 02-23-2020, 06:53 AM   #10
That's how I removed a 12X24 (over Ditra) that I chipped, Tom, worked great.
More photos once you've fixed it, k?
Unread 02-23-2020, 02:14 PM   #11
As long as you don't end up pulling most of the fleece off of kerdi, you should be okay. FWIW, thinset doesn't 'stick' to either Kerdi or Ditra. In the case of Kerdi, tile is help in place because it flows around the fleece, then cures, locking it in place. With Ditra, the tile is just held there mechanically because of the shape of the pockets...it's not 'stuck' to the Ditra at all.
Bathroom Re Tile Job - Quick Question Obione Tile Forum/Advice Board 2 05-25-2013 11:10 AM
Quick tile sealer question slazin Tile Forum/Advice Board 2 01-05-2009 06:21 AM
Quick Tile Installation question golfgod04 Tile Forum/Advice Board 14 01-23-2007 12:01 AM
quick question about thinset...need answer quick agoings Tile Forum/Advice Board 13 04-28-2006 06:19 AM
A quick hello and a quick question of tile and stairs. bmkiss67 Tile Forum/Advice Board 14 07-30-2003 09:09 AM
