Unread 01-27-2020, 06:10 AM   #31
vbtalent
I found a better pic..
VB
vbtalent is offline   Reply With Quote
Unread 01-27-2020, 09:34 AM   #32
If the tile installation we're discussing leads to that stairway, VB, you have a more serious floor height consideration. Or is this landing/stair transition a different area?
There are tile profiles made for that application. Google up Schluter Profiles and see if you can't find something applicable.
Unread 01-29-2020, 05:31 AM   #33
vbtalent
I think I've found a suitable transition on Schuler's web site...
I did want to ask about your plywood suggestion does it just need to be a specific type of external plywood? or will any external plywood work, I'm assuming this is related to its resistance to moister capabilities..
VB
Unread 01-29-2020, 09:25 AM   #34
Your plywood must be an exterior glue plywood. That will be evidenced by an exposure rating of EXT or Exposure 1 on the grade stamp. And it must have no face of grade lower than C.
Your local home center will usually have a BC grade plywood that is suitable.
Unread 01-29-2020, 06:31 PM   #35
vbtalent
Thank you.
You guys have been a great resource and it is much appreciated.
VB,
VB
Unread 02-06-2020, 05:34 PM   #36
vbtalent
Materials question for LFT install...
I've got to ask the pro's what there thoughts are when it comes to thinset and grout for large format tiles.
Do you like the big box store products or should I go the big tile store route?
The plan is to use DITRA so I need a modified thinset for it and an unmodified for the tile 24x24 itself.
HD - offers VERSA Bond @$19 ea.
Floor and Decor - Mapei Ultraflex LFT White - $30 ea.
Lowes - MAPEI Large Tile and Stone - $30
Tile Shop - Superior Pro-Flex Latex Fortified - $25
Suggestions???
... and for grout???
Lot's of choices out there...
VB,
VB
Unread 02-06-2020, 06:21 PM   #37
I've used tons of Versabond and Flexbond to stick down Ditra without any issues. I go against the rules on sticking the tiles. For large format tiles, I like using Custom's Natural stone and large tile thinset from Home Depot. I just give the tiles an extra day or two before grouting. I'm not using unmodified for porcelain tiles.
https://www.homedepot.com/p/Custom-B...-100154560-_-N
Unread 02-06-2020, 07:23 PM   #38
smifwal
I wouldn't use anything from the tile shop to stick down tiles. I didn't see it on your list so maybe it is not available. If you can get your hands on Ardex X5. This my day to day mortar
Unread 02-06-2020, 07:29 PM   #39
VB, it'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
Unread 02-07-2020, 06:44 AM   #40
vbtalent
CX, I wasn't sure if it made sense to continue in the same thread since it was a different topic... thanks for moving it.
Davey, aren't all 3 of those modified thinset's? If you use Versa for the DITRA why change when laying the tile itself?
Smifwal, Ardex doesn't appear to be a big seller around me and they make it in 40 lbs. bags instead of 50lbs, pricing seems to be in line.
Why the large price difference between the products, is it the cement in them?
I was hoping to save some money on this job, $30 for a 50 lbs. bag seems high to me but I don't do this for a living and don't want to cheapen out the job by using the wrong material just to save a few pennies today and have to redo it later.
Certainly appreciate the insight guy's.
VB
Unread 02-07-2020, 07:32 AM   #41
I used VB for nearly all my material setting, VB; Hardie board to plywood, Ditra (heat) to the Hardie, and porcelain 12X24's to Ditra (a modified is recommended for setting porcelain). You could use regular VB, mixed a little loose, for installing the Ditra, and then VB LFT for the tile.
Unread 02-07-2020, 08:17 PM   #42
VB, I was talking about installing large format tiles. The regular Versabond or Flexbond under the Ditra and then the Stone and large tile thinset under the tiles. It will hold up the tiles better than regular Versabond. Or, like Dan said, Versabond has a LFT version now, it can be used under the large tiles.
Unread 02-07-2020, 11:12 PM   #43
smifwal
Same coverage with a 40# as 50#. I have used all the major manufacturers products. I feel like I get the best results with Ardex. Pot life and smooth creamy consistency is what I like the most.
Unread 02-08-2020, 11:55 AM   #44
Some modified mortars need to dry in addition to curing. Drying doesn't happen very fast between DItra and a larger format porcelain tile. It could literally take months to dry. But, that generally only applies to some classes of modifiers - primarily those using latex. But, because Schluter doesn't or won't keep up with all of the various brands and their chemical composition, generically doesn't recommend a modified to use on top of their membranes except those that is makes itself or under contract. It IS needed to hold when bonding it to plywood, as an unmodified there would not likely survive long-term to bond with the plywood.
In some applications, it doesn't matter. For example, most cbu panels do not rely on the mortar to actually create the bond to the subflooring...the mortar is to fill any voids and hold the panel up...the fasteners hold it down.
Unread 02-08-2020, 12:27 PM   #45
Yes, but at the same time, the porcelain manufacturers recommend modified thinset to bond their tiles. I want to make sure the tiles are bonded well so I use modified (have every time for years without an issue). The thinset will cure enough usually over night to allow me to grout. If it's cool and damp, I'll allow an extra day. It takes longer to cure completely but it will. At least I know the tiles are bonded well.
Engineered floor trusses vs. dimensional lumber Kman Professionals' Hangout 19 01-28-2014 02:37 PM
Dimensional tiles over drywall fireplace facade erniepaul21 Tile Forum/Advice Board 3 11-27-2013 09:23 AM
Dimensional Tile Backsplash Novablue Tile Forum/Advice Board 6 10-12-2013 10:38 AM
setting three dimensional found objects leeanne Tile Forum/Advice Board 6 10-13-2010 06:47 PM
dimensional stone on wood tread fredm Tile Forum/Advice Board 5 05-24-2009 10:35 AM
