Unread 02-09-2019, 04:27 PM   #1
feh
fast way to set tile base?
Howdy all! We have a job we have to pop back into to to put up tile base (had to wait for drywaller to fix walls before we could do base). It would be ideal to get the tile base up as fast as possible and grout it same day. Is speed set the best option here, or could we do a fast set silicone adhesive to get the base up and grouted within 2 to 3 hours while having to unload the least amount of tools?
The base is a standard ceramic tile, bullnose, about 3 inches tall on drywall in a smallish bathroom
Sara
feh is offline   Reply With Quote
Unread 02-09-2019, 04:36 PM   #2
Topspin
SchluterUgrad
Topspin's Avatar
Perfectly flat walls you can get away with an adhesive. Here’s one that can do what you want. Could do the same with most any speed set thinset in just about the same amount of time tho.
https://www.tools4flooring.com/spray...-adhesive.html
Unread 02-10-2019, 08:05 PM   #3
feh
Wow, I've never even heard of such an adhesive. Have to admit, I don't trust adhering tile with anything out of a spray bottle haha.
Probably just stick with the speed set!
Sara
Unread 02-10-2019, 08:13 PM   #4
Nor have I, Sara.
I would be very skeptical of such a product, 'specially when they make statements such as the following. The TCNA does not approve products, be they good, bad, or indifferent.
Unread 02-10-2019, 09:47 PM   #5
Topspin
SchluterUgrad
Topspin's Avatar
This stuff works. I was comp’d five cans of it and tried a few for base tile. It definitely sticks but in the same amount of time it takes to protect the tiles from getting overspray, you could put Custom Speed Set and be done in the same amount of time. Additionally thinset will allow variations in the wall to be addressed.
Unread 02-11-2019, 12:12 AM   #6
You could stick them on with construction adhesive, too, Kevin, and avoid the over spray problem, Kevin, but I don't think I'd recommend that, either, although I'm quite confident it would work for a while.
Unread 02-11-2019, 07:52 AM   #7
RichVT
Vermont Remodeling Contractor
Hot melt glue. Works like a charm. Stick them up and grout immediately.
https://www.fastenmaster.com/products/flex.html
https://www.youtube.com/watch?v=S4r1VwxF8KU
Rich
RichVT is online now   Reply With Quote
Unread 02-11-2019, 10:16 AM   #8
speed51133
https://www.youtube.com/watch?v=1ieZe1LGgzw
Fast setting of tile baseboards? nascenta Tile Forum/Advice Board 7 09-13-2011 09:20 PM
Silicone or Grout where floor meets base tile. How about top of base tile? jmkeuning Tile Forum/Advice Board 15 08-08-2006 08:43 AM
Greenboard tile need answer fast!!! rellik321 Tile Forum/Advice Board 2 03-19-2005 04:00 PM
rebuilding tile shower - need help fast gertie Tile Forum/Advice Board 10 02-21-2004 10:45 PM
Fast Track Tile and Grout Jason_Butler Professionals' Hangout 9 03-09-2002 02:48 PM
