Unread 05-17-2015, 11:38 AM   #1
Tiger Mountain Tile Inc
Noble ValueSeal Waterproof Sheet Membrane
I was asked about ValueSeal over in this thread and don't want to derail the conversation over there.
Link to more information and data sheets
I've used this on a couple of projects now and I like it overall. It's obviously designed to compete with Kerdi and the like and is priced accordingly. Here's some random remarks about it:
  • It's stiffer than the others but it's still very thin. If you were to drop it on the floor it wouldn't just crumple up but would hold it's form somewhat.
  • Because of the above you can crease the corners and it will hold
  • It's translucent so you can see the coverage underneath it
  • Seams with thinset
  • It comes in 6 ft widths (and 3'). These are American widths- not that crazy metric system that's divisible by 10's.
  • Made in America
For me what I like about it most is the 6 ft width. In the photo below the membrane is continuous. It goes from the top of the back wall- across the shower pan- across the bath floor. A length of approximately 18 linear feet and has no seams or breaks.
(The water spot is from mudding the corbel under the bench)
Name:  curbless valueseal shower.jpg
Another photo of a different project:
Name:  TSR Watermark - 0201.png
Also, I like that they don't have a proprietary drain that they push on you. I like Ebbe drains and I can just use their (Noble's) drain flashing.
Name:  noble value seal ebbe drain.jpg
If you're an NTCA member you can order a kit this year that has the 6' membrane, the drain flashing, a tube of sealant, some corners, and some other stuff. That's what I used in the first photo was that kit.
Name:  Noble VS NTCA voucher.jpg
My swag from Total Solutions Plus last year:
Name:  2014-10-27 19.47.33.jpg
The Noble "hat" (flashing) never looked so good (any excuse to get this photo out )
Name:  Noble hat john bridge.jpg
I know other guys have used it. Post your photos and opinions of the stuff.
Jim Upton
DIYTileGuy
Unread 05-17-2015, 04:14 PM   #2
daveward
Jim, I appreciate all the commentary about the advantages and your experience. I checked the Noble website and noticed the product can be used with latex modified thinset. If my memory serves Kerdi is used with un- or non-modified thinset. Not knowing the difference, is this an advantage or not...or a big deal? Thanks again.
daveward is offline   Reply With Quote
Unread 05-17-2015, 09:23 PM   #3
When I install Kerdi membranes I follow the Kerdi instructions and use unmodified. When I install Noble's membranes I follow their instructions and use modified. Both Noble and Schluter have been in the membrane business for decades and both systems will work.
I think the main thing is to research the products that you want to use from the companies you trust.
Jim Upton
DIYTileGuy
Unread 05-18-2015, 06:15 AM   #4
That's a really old picture, Jim. I look much better now.
Unread 05-18-2015, 11:50 AM   #5
jondon
jondon's Avatar
Thanks for the information Jim, yes I like the larger size this way you can have less seams or none on a larger pan So you mean the overlap, thinset is that a 2" overlap like kerdi?
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 05-18-2015, 12:55 PM   #6
e3
yep--2" overlap
Eric
Noble Company
Waterproof sheet membrane The Kid Professionals' Hangout 5 03-21-2013 01:04 PM
Waterproof Membrane? Yes or No? tysondoesnttile Tile Forum/Advice Board 5 01-06-2011 07:22 AM
liquid membrane vs. sheet membrane Livinlarge Tile Forum/Advice Board 3 11-09-2008 11:33 AM
Question on Noble TS membrane fred goldby Tile Forum/Advice Board 1 09-02-2007 05:05 PM
Noble TS Waterproof membrane CenTextile Tile Forum/Advice Board 4 12-20-2006 09:12 PM
