Unread 08-27-2014, 11:54 AM   #1
Topspin
SchluterUgrad
Topspin's Avatar
New FLIR for Iphones and other smart phones
Looks promising to me. Flir technology for smart phones for $349. Sounds like a no brainer to me.
I cant tell you how many people call me to determine if they have a leak and how extensive the damage may be. I think something like this would do wonders for making active water leaks and wet areas show up for a quick close to a consultation.
Up till now the only ones that looked fairly promising were the $6K - $13K versions by same company.
Youtube
Unread 08-27-2014, 01:17 PM   #2
jcsa
Tile Contractor
Flir
Kevin thanks!
I have a bigger one, but it too expensive to carry around all the time. This is much more affordable and is being shipped as we speak. I will let you know how it works. John Cox
JC
Certified Tile Installer # 26
Cox Tile, Inc.
jcsa is offline   Reply With Quote
Unread 08-27-2014, 04:16 PM   #3
Thanks that is way cool (no pun intended)
Unread 08-27-2014, 05:51 PM   #4
not for me, I'm not a plumber or want to bother with doing leak investigations.
If they don't want the shower totally ripped out I'm not bothering.
Unread 08-27-2014, 08:36 PM   #5
Topspin
SchluterUgrad
Topspin's Avatar
Paul. What interest would that be to you with your broken screen which requires careful typing?
Brian, I'm not a plumber either. But when I can show a prospect that they have water where it's not supposed to be, I close them nearly every visit.
Easier to do with a FLIR instead of either opening a wall, or waiting for a prospect to think about the risk for weeks or months. If it works like I hope it can make prospect visits more productive = $$$
Looking to hear from your review JC
Unread 08-27-2014, 08:37 PM   #6
I show up when the shower has failed and there's rot and tile falling off.
there the best calls.
Unread 08-28-2014, 05:03 AM   #7
tilemanct
Tile & Stone
Wow
I was just looking at a FLIR camera for shower inspections. John I will be waiting to hear your review on the FLIR for I Phone. I cant tell you how many showers I have looked at over the last 4 months that are leaking. The FLIR I looked at was around $8K.
CTEF Certified Installer
Unread 08-28-2014, 06:19 AM   #8
Dave Gobis
da Man!
Dave Gobis's Avatar
I use one for leaks and in some cases thinset coverage.
Unread 08-28-2014, 06:58 AM   #9
JTile
Southern Delaware Tile Contractor
JTile's Avatar
Only works on Iphone 5 or 5s? Seems to me they are limiting their market.
Justin
Kyle's Tile LLC
Ocean View, Delaware
www.KylesTile.com
JTile is offline   Reply With Quote
Unread 08-28-2014, 07:54 AM   #10
Topspin
SchluterUgrad
Topspin's Avatar
Probably also good for drilling in heated floors. I have one coming up where the client wants a door stop on a funny angle so have to drill for one in the heated area.
I'd assume you could see the wire pattern and drill without fear.
And thinking about it, Brian has a good point that falling apart showers are pretty easy to close the deal. However if given the choice, I would rather replace a slightly wet shower with little damage, than a mold monster. If I could fill my year with slightly wet than I can pass on all the stinkers going forward.
Unread 08-28-2014, 10:14 AM   #11
jcsa
Tile Contractor
Smaller
Kevin,
We have used our big Flir for locating the wires for door stops. We have also used it to detect where wires were damaged when one wasn't used. I am looking forward in having one that is small and portable...and less expensive. There are a lot of uses for this device. I will respond when i take it for a test run. Should have it in a couple of days.
JC
Cox Tile, Inc.
Unread 08-28-2014, 06:16 PM   #12
yeah, but to me people would try to just get the leak fixed and your out a full shower. Mold isn't that bad but I prefer the termite damage the best
full rip out for curbless shower and the lady was lucky she went that route.
her deck and all studs were ate up by termites all except for the exterior PT.
Unread 08-29-2014, 04:44 AM   #13
tilemanct
Tile & Stone
John & Dave,
What model IR camera do you have?
Unread 08-29-2014, 05:00 AM   #14
jcsa
Tile Contractor
Flir
I have the Flir i7
JC
Cox Tile, Inc.
Phones for contractors tilerite The Mud Box 24 02-28-2014 12:21 AM
How smart do you have to be... ddmoit The Mud Box 12 04-03-2010 09:40 AM
Cell Phones replacing Land Lines ???'s Marge The Mud Box 27 02-26-2009 06:15 AM
