Unread 11-02-2013, 05:03 PM   #1
madronatile
curbless shower pan mosaic buildup
Any ideas on a good way of building up beneath the shower pan mosaic when it's way thinner than the adjacent field tile in a curbless install?
Sorry for the run-on. Thanks!
Matt
www.madronatile.com
Unread 11-02-2013, 06:14 PM   #2
Matt,
How was the shower floor constructed? Surface applied membrane? Which one?
Unread 11-02-2013, 09:46 PM   #3
Calgary Dave
Use 1/8" Wedi board?
Calgary Dave is offline   Reply With Quote
Unread 11-02-2013, 10:02 PM   #4
TileArt1
TileArt1's Avatar
Ditra with kerdi over it to slope down to the mud deck.
Roger (The FloorElf)
Unread 11-03-2013, 08:15 AM   #5
lati_cz
michal
Use trowel of size you need and spread thinset evenly in shower pan, let it dry, fill the voids.
Michal
lati_cz is offline   Reply With Quote
Unread 11-03-2013, 09:19 AM   #6
TGR
I have done this in different ways as well. I had to fix a poorly sloped pan with lots of bird baths last summer built by a different installer. I bonded “type S” to the pan with thinset. After the “S” cures to a point you can carve it quite nice. Last time I had your situation I pre bonded some pan tile to kerdi and just built up thinset to make a nice transition. I know whatever you do it will be most excellent because that is how your stuff turns out. Let us know what your method turns out to be.
Todd
TGR is offline   Reply With Quote
Unread 11-03-2013, 09:23 AM   #7
How thick are we talking? Read the label on Laticrete thinsets and you'll be surprised how thick some of them can go.
Unread 11-03-2013, 02:12 PM   #8
Tiger Mountain Tile Inc
The way that I've done it is to simply build up the pan higher. I don't have great photos of this but the first one is a traditionally built cbu curbless shower with a liner.
Cut me a little slack on the surface waterproofing. This was a few years ago and I would do a wider section now. I'm always learning.
Jim Upton
DIYTileGuy
Unread 11-03-2013, 02:21 PM   #9
Here's my one and only liquid shower. Curbless divot, with Ditra, and Aqua Defense. It's harder to tell but the shower pan is built up higher than the main floor.
Jim Upton
DIYTileGuy
Unread 11-03-2013, 04:19 PM   #10
T_Hulse
Tile Contractor
T_Hulse's Avatar
I do it similar, Jim. The 1/8" step-up is for the Kerdi-Ditra transition. The inside higher mud bed looks like it is one slope on one plane, but it is actually two. 90% of that higher bed is aiming right where it needs to be, but for the last foot, I flatten the slope a little so the waterproofing can go underneath the big floor tile outside the shower, then I build the slope back up by floating thinset to a tiny screed stick after the Kerdi is in. That way all water outside the shower will still drain nicely if it is anywhere near the edge.
Tom Hulse
Visit my web site here
Unread 11-03-2013, 07:53 PM   #11
K_Tile
Member of Million SF Club!!
Curbless showers have the whole room waterproofed. I lay bathroom floor tile first then screed thinset off the floor tile for thinner shower pan tile.
Unread 11-03-2013, 09:56 PM   #12
madronatile
Thanks for all the replies. I don't think I can guesstimate the different buildups so I think we'll do the thinset after waterproofing approach.
Matt
www.madronatile.com
Curbless Shower Pan Options arc2v Tile Forum/Advice Board 42 01-08-2014 01:20 PM
Curbless shower pan in slab enormis Tile Forum/Advice Board 11 08-13-2013 09:38 PM
5/8 mosaic on kerdi shower pan MarkJohnson Tile Forum/Advice Board 2 07-20-2010 05:23 PM
Curbless shower pan poured as part of a slab on grade crashman250 Tile Forum/Advice Board 4 08-28-2009 10:23 AM
Shower Pan buildup - offset drain Hokie01 Tile Forum/Advice Board 3 11-15-2007 06:29 PM
