Unread 09-30-2013, 07:44 AM   #1
jm66210
Tiling over tile
Ugh...Going to go look at a job tomorrow that involves tiling over an existing tub surround. I haven't seen it yet, but they say it's "sound" , just ugly. 1930's house, so it's tile over mud, with mudcaps & typical trims. Any ideas? Would this be an application for kerdi board? Should they call bathfitters?
Jim
jm66210 is offline   Reply With Quote
Unread 09-30-2013, 07:53 AM   #2
MDtile
What kind of tile do they want to put over it?
Any problems with the control valves with another tile thickness added?
MDtile is offline   Reply With Quote
Unread 09-30-2013, 09:14 AM   #3
jm66210
should be able to manage the valves/spout. Gonna use whatever tile I suggest. Probably 4 x 4 ceramics so I can get the necessary trims to go with it.
Jim
Unread 09-30-2013, 10:07 AM   #4
MDtile
You can use 2x6 radius (A4200) cut down to make a "long" quarter round.
Make sure to TSP it, and use a bonderizer before tiling.
Unread 09-30-2013, 02:14 PM   #5
without seeing it, add one vote for kerdi board thinsetted over the tile
Unread 09-30-2013, 08:28 PM   #6
Be mindful of how narrow the back shoulder (ledge) of the tub is. Specifically in the middle of the 5' wall where the shoulder typically gets pretty narrow. Adding thickness over an existing tile job might be too thick to the point where it overhangs the wall of the tub. It would be unsightly.
Unread 10-01-2013, 08:15 AM   #7
jm66210
Yep, good point on the shoulder thickness. Kerdi board adds just that more thickness too, but I think a waterproof layer is important. Any other options?
Hydroban, redguard, kerdi, between the old & new tile? Thanks!
Jim
Unread 10-01-2013, 08:32 AM   #8
Kerdiboard comes in many thicknesses from 3/16" to 2"
You can also use kerdi fabric over the tile to save even more room.
Unread 10-01-2013, 11:47 AM   #9
Peerless Tile
Tile Contractor
May want to check out a Mapei product called Eco Prim Grip....May be just what your looking for in the situation at hand. It's made just for this process.
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 10-01-2013, 10:15 PM   #10
PetrH
I'm in the John Holmes school of thought on renovating. Wherever possible tear it down to studs and start over. But sometimes that's just not in the cards. Thinset bonds really well to most tiles, if they are roughed up.
Some guys just get carried away, I definitely would not call myself a hack, but I see no problem with just roughing up the glaze with a diamond cup wheel and tiling over the old tile. Putting kerdi, kerdiboard, hydroban, etc on it just adds cost and thickness. If the old tile stayed put for 80 years, it should last a few more.
Petr
Unread 10-01-2013, 10:20 PM   #11
Deckert
Its its been in place for 80 years, I'd try to get them to take out the old completely. You won't ever get a better chance to bring the drain and trap, the supply lines, the valve, the framing, etc up to snuff. Then you can build something that will last em that long again.
Brannigan
HeenanGC.com
Unread 10-02-2013, 02:59 AM   #12
jm66210
Went and looked at the bath today. Tiling over tile just doesn't seem to make sense to me, and is just prolonging the inevitable. Seems like it would be creating a moisture sandwich as well. There are a few hairline cracks radiating from the plumbing fixtures which may or may not cause problems. Tub is etched anyway & will need to be replaced in time. They suggested having the tub "restored" by miracle method so I suggested they have them do the whole bathroom. That would be a good 5 year solution, eh?
Jim
Unread 10-04-2013, 07:44 AM   #13
jm66210
They are begging me to do the job, so I looked into the Eco prim grip. I just don't see the benefit of using a product like this as opposed to using something like laticrete 254. I explained that this job gets a "rear view mirror guarantee", and will just add to the demo cost in the future.
Jim
Unread 10-04-2013, 06:12 PM   #14
Peerless Tile
Tile Contractor
You would use the prim grip ALONG with a quality thinset like 254....save the scarifying process and create a sound bonding surface without all the dust.
SC Greg
Tiling outside corner with glass tile. Also ending 1/2 wall tile at tiled shower cmarks927 Tile Forum/Advice Board 13 03-11-2011 06:24 PM
Tiling newbie with some questions - tiling over tile, etc rickcr Tile Forum/Advice Board 4 12-05-2010 04:00 PM
tiling over tile? craig99 Tile Forum/Advice Board 7 02-22-2010 05:14 PM
Wall tiling around corner & Tiling ceiling into skylight Eighth Wonder Tile Forum/Advice Board 3 08-10-2009 03:46 AM
Tiling over old tile CTBob Tile Forum/Advice Board 3 12-31-2007 08:31 PM
