Unread 08-29-2013, 04:06 PM   #1
Dan Kramer
Registered Tile/Stone User
Dan Kramer's Avatar
Accents curling
Tried to set some of these today and couldn't keep them flat. Wanted to curl even more with pooky on 'em.
They're going between 12x24's and I need them flat. Ideas?
Mine was to glue them to kerdi lay a board over them and park my truck on it.
Dan Kramer is offline   Reply With Quote
Unread 08-29-2013, 04:17 PM   #2
dhagin
Glue to the thin wedi board, 3/16 i think. We do this with mosaics or rocks sometimes. Might need Latapoxy 300 if the curling is water/moisture related.
dana
Unread 08-29-2013, 04:31 PM   #3
That 1/8" wedi is the cats meow
Unread 08-29-2013, 04:53 PM   #4
Dan is that meow tile made of meow Metal ?
if so meow that looks like a pain to meow install
meow
Unread 08-29-2013, 05:45 PM   #5
Take them apart and install them individually
Unread 08-29-2013, 06:37 PM   #6
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Is that plastic face mounted?
Brad
Unread 08-29-2013, 06:47 PM   #7
Dan Kramer
Dan Kramer's Avatar
I like the idea of the Wedi board. Unfortunately, it is 3.5 hrs to Virginia beach or 4 to Raleigh. One way. I won't be swinging by on my way to work maƱana to grab a piece.
I live at the blue dot.
Unread 08-29-2013, 06:50 PM   #8
Dan Kramer
Dan Kramer's Avatar
Brian, it is metal. Paul I've got 18 lineal feet to install and as tight as it is I don't think it could be installed in individual pieces in any sort of timely manner.
Unread 08-29-2013, 06:51 PM   #9
Dan Kramer
Dan Kramer's Avatar
Brad, mesh on the back.
Unread 08-29-2013, 07:21 PM   #10
They might have got damp and curled and dried that way. I would wet the mesh a little bit and lay them on something flat and put something flat and heavy on them and let them try. Maybe they will re-dry flat
Unread 08-29-2013, 07:27 PM   #11
You live at the blue dot ?? I Never want to hear you complain again. That is some beautiful country.
Unread 08-29-2013, 09:30 PM   #12
dhagin
Have supplier rip the wedi to what width you need & fedex to job? Have it monday waitin for ya. I like Brians idea too. ... the rewet one, not the meow one.
dana
Unread 08-29-2013, 09:47 PM   #13
madronatile
Maybe some temporary hot glue splint or something? Need the hot glue-ru katwyck to chime in.
Matt
www.madronatile.com
Unread 08-30-2013, 04:25 AM   #14
Brad Denny
Brad Denny's Avatar
Yup, I like Brian's idea too.
They look pretty thick. If they don't flatten out after wetting them, do you think you could cut into the back and insert something like a rod into the groove? Probably need to do two per sheet, maybe a 4" or so in from the edge.
Time consuming.
Brad
Unread 08-31-2013, 02:39 PM   #15
Dan Kramer
Dan Kramer's Avatar
Interesting idea, Brad.
Brian's idea sounds good but wouldn't the moisture in the thinset cause the same issue as it is drying on the wall?
looking for chrome accents...no luck so far sambette Tile Forum/Advice Board 6 05-10-2010 03:51 PM
Glass Backsplash Accents Dennisfly Tile Forum/Advice Board 2 04-19-2010 12:10 PM
Curling johntrent Professionals' Hangout 11 03-19-2009 08:44 PM
Glass tiles as accents zel Tile Forum/Advice Board 13 11-18-2003 10:44 AM
curling mud william hendry Professionals' Hangout 6 06-06-2002 08:12 PM
