Unread 12-03-2018, 06:38 AM   #1
Forcing warped planks flat
Okay, so we all have dealt with warped tiles and now we see more and more leveling systems coming along. Here is one I was watching this morning.
https://www.youtube.com/watch?v=I3Q015R7LxA
The question I have, does it hurt anything to force the tiles to lay flat? Looks like they would stay under stress (like a leaf spring). Is this bad, or no big deal? What's your opinion?
Unread 12-03-2018, 08:58 AM   #2
I think we've had a thread on this previously, but there's no telling where it is.
I'm in the school that thinks the constant tension between tile and substrate might be a problem. I don't know why or how. I just think it.
Unread 12-03-2018, 09:41 AM   #3
It probably does keep some tension to it, I've used clips for 3' or longer planks because it does bring them into a plane flatter then they were made. Anything under they don't do anything for me good prep wouldn't do.
I've gotten some amazing results with them, but admittingly don't know the long term effects of tile under tension.
Unread 12-03-2018, 06:52 PM   #4
Karls tile Inc
We use them on all of our jobs. As long as the tile is properly installed I don't think the tension will be a issue.
Karl
Karlstile.com
Unread 12-03-2018, 11:05 PM   #5
Bond strength of a cured good modified thinset is in the order of 3-400psi. If the bond is able to cure sufficiently prior to release of the leveling clamps, it should be okay. If they were warped a lot, I might want to leave things in place a bit longer than overnight before removing the levelers just to be sure, but I have no data on that.
Unread 12-04-2018, 05:59 AM   #6
I'm on the fence, I feel like it's not a good thing but I think a good thinset and prep work should hold the tiles down just fine.
Of course the clips are pulling up on one tile as it pushes down on it's neighbor. Another concern I have is a corner lifting up out of the thinset after the thinset notches have been flattened out. I doubt this is a major problem but could see it happening.
Unread 12-04-2018, 08:28 AM   #7
This is probably one of the questions we can't answer in the short run. The test of time will tell.
Unread 12-04-2018, 06:07 PM   #8
That's true John, now Davy from one stubborn guy to another... get yourself some no lip clips and try it on some long planks. Keep mudding but live a little
Unread 12-04-2018, 06:51 PM   #9
Need to bear in mind that the longer tiles need to be forced down to flat before tightening the leveling clips. Use your knee or your ex wife to do this.....After they are kinda flat, THEN tighten up the clips. You don't use them to pull the tiles "into plane"......You use them to hold them properly after the tiles are right.
Unread 12-04-2018, 06:54 PM   #10
I'm trying.
Unread 12-05-2018, 09:08 AM   #11
Davy,
If Gobis was still running the tile school I'd send you on an expense paid trip to South Carolina to get you up to date on modern tile installation. That's what he did to me years ago, and I've been doing membrane showers ever since (as you know). Dave will tell you I was every bit as hard headed as you are.
Unread 12-05-2018, 09:45 AM   #12
Dave Gobis
da Man!
Dave Gobis's Avatar
I think probably more.
Unread 12-05-2018, 07:38 PM   #13
With all due respect, You're still hard headed, John. You won't give up.
As for floors, I think I mentioned, I'd rather spend extra time getting the floor as flat as I can instead of spending time with clips. But, I understand if someone wants to use them. I'm cool with that.
For showers (here we go again ), I want my walls flat, plumb and square with each other. To me that's important with the crooked walls we are seeing and the large format tiles folks want. For me, mudding them is the fastest and easiest way to accomplish that. I understand it's not for everyone. Besides, why change methods, then I'd have to lower my prices.
Unread 12-06-2018, 08:46 AM   #14
Well, I've got to tell you I agree that mud is the best way to go for walls that are way out of whack. All of the membrane showers I've done have been taken right down to the studs, so getting them in shape was never much of a problem.
Small Floor -> Large Tile and How Flat is Flat? Eldudarino Tile Forum/Advice Board 9 09-23-2016 12:53 PM
Warped Tub help needed rhea94 Tile Forum/Advice Board 5 05-18-2014 11:39 PM
best way to tell if floor is level/flat-and other flat surface issues!? acid Tile Forum/Advice Board 9 05-12-2005 10:32 PM
warped tile joneswil Tile Forum/Advice Board 5 12-21-2004 11:19 AM
