Unread 06-28-2021, 04:23 AM   #1
openhand
Gandolf
Subway backsplash on plywood cabinet side?
Hi All- Can you recommended the best product for setting subway tile on the side of a new cabinet? This is backsplash for a slop sink. Is modified thinset ok here? Most of the backsplash will be backer board but the side is a tall cabinet. Thanks!
Clark
openhand is offline   Reply With Quote
Unread 06-28-2021, 07:39 AM   #2
I know of no tile setting product that is indicated for use over a hardwood plywood, which is likely what you have there, but it's an application where I would actually favor an organic adhesive rather than a thinset mortar.
What, pray tell, is a "slop sink?"
Unread 06-28-2021, 10:03 AM   #3
mdnky
"Slop sink" is another term for a stationary tub/utility sink usually found in mudrooms or laundry rooms.
~Michael
mdnky is offline   Reply With Quote
Unread 07-05-2021, 06:22 AM   #4
openhand
Gandolf
Gooanswer on the slop sink! It’s a high end mud room. A stainless under mount-sink and granite counter. Backer board behind, but a tall cabinet encloses the counter about 5 inches away on the left. I want to stick tile directly to that so it isn’t too thick. What is an organic adhesive? It won’t be too splashy in that spot- does everyone think it will be durable if I set tile directly on it as opposed to somehow attaching a thin backer?
Clark
Unread 07-05-2021, 08:08 AM   #5
Organic adhesive is commonly called mastic, Clark. Comes in a bucket. Says it meets ANSI A136.1.
3X6 Tumbled Marble wall tile without grout and applied to the side of a cabinet rokanije Tile Forum/Advice Board 2 12-07-2014 07:00 PM
How to tile onto wooden cabinet side housing bath filler? enduring Tile Forum/Advice Board 53 01-21-2013 09:14 PM
Cabinet - tile behind side or up to? funky5 Tile Forum/Advice Board 4 04-19-2007 09:50 AM
Granite tile sidesplash on side of cabinet ShirleyK Tile Forum/Advice Board 1 03-11-2007 05:11 PM
Tile To Cabinet Side... Higgy Tile Forum/Advice Board 5 01-04-2006 01:18 PM
