Unread 12-31-2021, 08:50 PM   #1
AntoAll
Very unmaintained marble ?
Hello,
First, I'm a carpenter but very unexperienced with tiling!
I recently moved in an appartment as a tenant, and the bathroom is all tiles. I don't know exactly what type of tiles it is but it feels really marble to me. Maybe I'm wrong if someone can correct me ?
The problem is that it is very dirty and I would even say damaged.. The ex tenant told me he tried to clean it before but with acidic solution like CLR, and maybe he let it on there for too long ?
I've tried different products on one tiles and nothing seems to help.. So I was reading about diamond pads with a polisher is what I need but I wanted to get solutions from pros, so here I am !
If anyone with experience could help me, I would be really be grateful.
Thanks guys and happy new year !
Antoine
AntoAll is offline   Reply With Quote
Unread 12-31-2021, 10:56 PM   #2
Welcome to the forum, Antoine!
Yeah, the use of CLR was a rather large mistake. It appears to have severely etched the surface. There’s no “cleaning” that will help. You appear to be on right track with wanting to polish the surface to remove the micro-fine rough, etched surface to restore an extremely smooth, polished surface.
Polishing the surface of tile isn’t hard using wet polishing pads and water. But it’s hard to avoid a wavy surface with a small, single pad. Usually, it takes a lot of practice and more advanced equipment. And it’s rather challenging containing all the water.
The floor tile appears cracked. If that’s the case, there’s no halting that damage.
I’m assuming you’re just trying to make it better while you’re there and looking for any helpful info you can get your hands on? And do I dare ask if the owner has given permission to attempt repairs?
Unread 01-01-2022, 05:58 AM   #3
AntoAll
Hi, thanks for the quick reply !
You are absolutely right, I'm just looking to make it a little bit better, I do not really care about the cracks and big repair, I just want to make it so it looks a little more clean.
I did not ask the owner yet, because I did not know exactly what was going on and what is needed to work on the tiles, once I know a little better on what to do I will definitely discuss it with him.
Antoine
Unread 01-02-2022, 08:04 AM   #4
Tile & Stone Guild
King Of Tile
Looks like Negro Marquina or similar. This stone needs to be finished with oxalic acid to get the color and shine to pop. There's a fine line between a good job and "orange peel" from too much acid and burnishing.
I don't recommend attempting this stone in a customers home and your first foray into the fold.
Jeff
Unread 01-02-2022, 08:32 AM   #5
AntoAll
But do you think that diamond pads and water can make a good job of juste getting the CLR off or would it just make it worst?
Antoine
Unread 01-02-2022, 11:08 AM   #6
jerrymlr1
jerrymlr1's Avatar
Those dull spots may a or may not be from the CLR Antoine. I've seen water do the same thing to marble from just sitting on it for too long. Depends on the water.
As for polishing to get the CLR off, it's not going to happen. Something has etched the stone and the diamond pads would bring the "rough" surface back to a polished state similar to using fine grit sandpaper to bring rough wood to a smooth surface. It's not an easy task with stone though.
Jerry
Unread 01-03-2022, 12:46 PM   #7
Tile & Stone Guild
King Of Tile
You will get it to shine but it will look grey without hitting it with oxalic afterwards. You will also have visible swirl marks.
Jeff
Bonding Marble to Marble Jay Jolliffe Tile Forum/Advice Board 5 02-26-2019 06:14 PM
Attaching marble baseboard to marble wall dBessey Tile Forum/Advice Board 2 02-12-2018 06:58 AM
Marble stone tile over Cultured marble slab shower walls Tap2112 Tile Forum/Advice Board 10 11-30-2015 08:42 PM
questions about threshold/support for marble - marble transition dnsgrrl Tile Forum/Advice Board 23 12-12-2014 01:35 PM
prepping shower for marble installation + finishing marble edges rusty Tile Forum/Advice Board 2 07-02-2008 07:53 AM
