Unread 04-30-2016, 07:14 PM   #1
Shel8043
Help installing travertine pool coping
We are going to install travertine coping and a concrete pool deck. I am finding very little installation information. We are doing it all ourselves. It is a vinyl liner pool, so it will be installed on the metal beam of the pool and the concrete base we made for it to sit on. It will also be on the top edge of our steps and swim out so we need to secure it to them as well which are plastic. What would be the best thing to lay them with? We had read Flexbond or a flexible mortar due to freeze/thaw, but will that adhere to the metal beam and plastic stairs? Also how deep does the mortar need to be? I read 1", does that sound right? Do you want to lay them level or slightly sloping away from pool for runoff?
How wide should the expansion joint between the coping and the concrete be, and what do you fill it in with? Lastly, what do you grout it with? Just regular sanded grout? Sorry for all the question! Thank you!
Michelle
Shel8043 is offline   Reply With Quote
Unread 05-01-2016, 02:08 PM   #2
dhagin
Welcome Michelle.
I think we're gonna need a few photos here. You want to install over metal & plastic?
dana
Unread 05-01-2016, 06:32 PM   #3
Karls tile Inc
Tile and stone contractor Tile setter
To be honest you should hire a pro. You have expensive material and you lack the knowledge that comes from years of experience with installing similar jobs.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 05-01-2016, 06:37 PM   #4
Karl, this is a DIY forum and we try to help the visitors do the projects they are asking about, rather than telling them they should hire a professional. There are occasions when we'll come to the conclusion with the particular visitor that the project is beyond their individual capabilities, but thus far we don't know enough about this product nor this visitor to make such a conclusion, eh?
Unread 05-01-2016, 07:05 PM   #5
Autoplay
Tile Setter
Installing over metal and plastic,egads lol. Only product I would use in that case,would be an epoxy,for bonding. Expansion and contraction issues to be considered too,esp if you live in a freeze/thaw area.
All that being said,I wouldn't bond over either,with what you're describing.
I would go over a footer,cinder block footing etc,or I wouldn't do it.
Rich
Travertine Pool Coping/Deck DFYguy Cleaning, Restoration and Sealing 3 07-31-2015 07:50 PM
About to install travertine coping over fiberglass pool jwramr Tile Forum/Advice Board 2 06-27-2015 10:13 AM
How to restore travertine coping around pool. mgianzero Cleaning, Restoration and Sealing 7 06-23-2014 08:22 AM
Installing Precast concrete Pool Coping over Existing cantilever Kooldeck majorjer Tile Forum/Advice Board 2 08-09-2010 10:32 AM
travertine for swimming pool coping dogpoundmike Tile Forum/Advice Board 3 05-09-2006 05:31 PM
