Unread 12-31-2013, 12:12 PM   #1
gerry_foster
schluter line drain advice
Good day all,
I am starting construction on my basement bathroom.
Our house is built on solid rock so doing a traditional method of waste removal is out of the question.
I have got all the parts now to construct the bathroom, however I need some advice on one part.
Here is what I have.
Saniflow snaishower pump
Schulter line horizontal drain system (imported from the UK)
Kerdi 55"x55" pre sloped pan from Canada
So the UK version of the pre sloped pan was very large and fragile so I did not want to chance importing it as well. The only difference is that there is a 2" thick spacer to go under the pan to make up the height difference form the Canada/us vertical drain vs the UK horizontal.
So my question is......can I just use 2" eps sheeting from the home store and mortor down before the pan like the UK instructions show? I'm not sure if the eps Schulter uses is somehow different for it to bond with thinset?
Any advice would be great
The pics attached show the pan and drain, and the uk instruction page
Please note the walls are still just sprayed foamed and will be studded and Kerdi board attached.
Gerry
gerry_foster is offline   Reply With Quote
Unread 12-31-2013, 12:13 PM   #2
Lakee911
Perhaps put some deck mud under it and bond it with thinset?
Lakee911 is offline   Reply With Quote
Unread 12-31-2013, 12:16 PM   #3
gerry_foster
Thanks Lake.....this was my original thought......as I'm worried about compression overtime of the eps.
Gerry
Unread 12-31-2013, 12:27 PM   #4
eurob
Not...Sure
Usually the drain goes near the wall and the height of the drain is where you cut the Schluter foam sloped pan .
If you need a 2'' thick to properly connect the drain -- do you ? --, why you don't do a mud sloped bed to accommodate the drain height ?
Roberto
Unread 12-31-2013, 01:03 PM   #5
gerry_foster
Thanks eurob.
http://www.schluter.co.uk/produkt.as...g=verarbeitung
The pic at the start of this link shows a good exploded view of the system. I do not have the 2" none sloped spacer. This is what I am looking for help with.
Cheers
Gerry
Unread 12-31-2013, 01:21 PM   #6
Have you tried calling Schluter in Canada?
I do not know the density of the foam Schluter uses, but compared to some, it is fairly dense. They do not, to my knowledge (verify with a call) have any special coating on it to help with mortar adhesion like Wedi (which also helps their panel with vapor transmission). The crystalline structure of mortar grows into and bonds with foam quite well.
When covered with a sufficiently sized tile and mortar and the membrane, Schluter says the compressive strength of the assembly is 500#/sqin.
Unread 12-31-2013, 01:28 PM   #7
gerry_foster
Thanks Jad. Glad to hear that thinset will bond properly to foam....I assumed as much but I'm no expert. I've talked to Schluter a few times now and there have not been much help......especially trying to bring in a uk product. Had import the drain myself from Scotland. I'll give them a shout again
Gerry
Unread 12-31-2013, 02:05 PM   #8
eurob
Not...Sure
I see now where you get the reference of the '' sandwich '' .
If the necessary build up is 2'' + the sloped pan , K-board may do the trick . Make sure you get the Schluter's approval to install the board under the foam pan .
On the other hand , mud bed can easily raise the floor -- 2'' thick build up -- if this is the only issue . But doing so , I would consider doing a mud bed for the entire shower without using the foam tray .
Roberto
Unread 12-31-2013, 04:43 PM   #9
JustBecause
Gerry -
I am in the middle of a kerdiline drain too. Having fretted over mudding and looking into all the trays (for months), I finally settled on the mud. Just my 2c - it is easier than I thought.
Jay
JustBecause is offline   Reply With Quote
Unread 12-31-2013, 04:55 PM   #10
gerry_foster
That's good to know. I have the pre sloped pan already....however that. Doesn't mean I have to use it.....
Gerry
Unread 01-01-2014, 11:28 AM   #11
gerry_foster
slc selection question after reading SLC article
Happy new years guys and gals!
Need to slc my 10x10 basement floor bath......read the article and learned alot.....
However, to do a 100 sq Ft area, do I need to order in ES or can I get away with RS?
My floor has just been prepared with a 10" diamond plate grinder to get 2 layers of paint off and knock down the high spots. Still need a good 1/2-3/4 thickness to correct a bad taper and low spots.
I have no problem sp ordering in ES if it will be easier and better in the long run...
Cheers. Gerry
Gerry
Unread 01-01-2014, 11:40 AM   #12
Richard Tunison
Retired Tile Contractor
Just say NO to RS. It goes off way to quick for my liking.
Richard
Richard Tunison is offline   Reply With Quote
Unread 01-01-2014, 12:05 PM   #13
Yep, what Richard said. RS stands for Rapid set and there is no time for coffee breaks. Although, it is handy when I need to climb back on it to apply a second coat.
Slower setting SLC suits me better these days.
Unread 01-01-2014, 12:55 PM   #14
gerry_foster
Okay great thanks for the advice.
So I just fired up the laser to shoot the floor. Looks like I'm in need of 1 1\4" in one corner to bring it up perfect. Is this too thick for one pour? The center of the floor is 1/2-3/4". Room is almost perfect east to west, but very bad north to south.
Gerry
Unread 01-01-2014, 01:33 PM   #15
The RS and ES can be poured to 1 inch thick with each application. Be sure and use the primer first and dam up anywhere that you don't want it to run.
New Bathroom project and Need advice notacos4u Tile Forum/Advice Board 7 03-21-2015 08:32 PM
Advice Welcomed for Bathroom Project Mechanize Tile Forum/Advice Board 29 02-03-2014 12:48 PM
New Bathroom Project - Need Advice mariner72 Tile Forum/Advice Board 23 06-17-2013 12:43 PM
Bathroom tile project advice... capybaras Tile Forum/Advice Board 6 11-28-2009 10:35 PM
Need Advice on Bathroom Project Curious George Tile Forum/Advice Board 4 11-05-2001 07:02 AM
