Unread 03-20-2020, 12:46 PM   #1
speed51133
Recommend a mortar
Cultured stone, indoors, on cement board, above fireplace. Here is the instruction sheet. https://www.culturedstone.com/resour...llation-guides
The specs are below. I found a mortar that is meets one spec, c270, quikcrete Mason mix no. 1136, but do I also need admixtures or anything?
Any recommendations?
Unread 03-20-2020, 03:21 PM   #2
Instructions are a bit nebulous. You planning to use the method they show with their stones bonded directly to the CBU or the one they describe with the cleavage membrane and metal lath, Mike?
They indicate a modified mortar, but I don't know what that means to them.
Unread 03-20-2020, 03:37 PM   #3
speed51133
Direct to the cbu.
I know. I'm a bit confused
Unread 03-20-2020, 03:50 PM   #4
I don't like any of those veneer manufacturers' recommendations of the use of masonry mortar for installation, 'specially the ones that even indicate the use of Type N mortar. And I know they've had a rather large percentage of failures in those installations over the years, to the extent that at least two, probably more, tile installation product manufacturers have developed installation systems for those manufactured veneer products.
You might wanna contact Laticrete or Custom (and probably MAPEI) to see which of their products they might recommend.
For an interior installation I would likely just bond the veneer material directly to the CBU using one of the modified thinset mortars, possibly one of the LHT mortars depending upon the back of the veneer, and never look back.
If your veneer is very thick and made to have pointed mortar joints, that may be a different story.
Unread 03-20-2020, 04:01 PM   #5
smifwal
Ardex X5
Unread 03-20-2020, 06:01 PM   #6
Mason's mix will grab onto the lath but won't bond as well to the stone as thinset. Usually the stones are fairly rough on the backs but I've still seen them break bond when fat mud (Mason's mix) was used, especially outside.
I've never used Ardex but trust Shawn's choice. Many here say positive things about Ardex products.
I have used this Customs thinset for large stone and was impressed. Home Depot has it. https://www.custombuildingproducts.com/TDS/TDS-309.pdf
need a new saw. what do you recommend? phillytileguy Professionals' Hangout 185 09-22-2017 06:39 PM
Please recommend... Tom Frykman Professionals' Hangout 5 01-21-2015 07:27 PM
What Wet Saw Would You Recommend??? kirkw12 Tile Forum/Advice Board 12 04-08-2009 04:13 PM
Can Someone Recommend A Tile Guy? TennJack Tile Forum/Advice Board 0 03-28-2007 09:53 AM
Is this efflorescence? If so, what would you recommend? Rafael Cleaning, Restoration and Sealing 29 02-10-2006 09:16 PM
