Unread 03-02-2020, 07:33 AM   #1
djproch
Shower Pan construction w/ Durock drain
Can anyone give me some pointers to using the former durock drain and waterproofing system with a traditional mud pan?
Currently I have 6" of drain pipe extending up from my 3/4" T&G subfloor, and I'm planning on putting a layer of plastic sheeting or felt paper and metal lathe on top of the plywood and then putting in a traditional mud pan that will slope from 1.75" at the perimeter down to 1.25" at the drain location to achieve a 1/4" slope. To this, I will add the durock shower drain and then top everything with their waterproofing membrane. What would be the best method for installing this drain w/ a mud pan? I have tried searching the internet for the recommended procedure but can't seem to find anywhere that shows me the installation w/o the foam base. I'm guessing that I should somehow measure and cut the drain pipe accurately enough to ensure my drain will sit 1.25" above the subfloor and glue this in place; I would then pack the mud underneath the drain flange and proceed with sloping the rest of the mud to the correct pitch at the edges of the shower.
djproch is online now   Reply With Quote
Unread 03-02-2020, 10:39 AM   #2
Our pal Sal Diblasi has an excellent video for you.
Granted its one of his older ones where he doesn't talk your ear off, but its still good.
You are correct
Unread 03-02-2020, 11:51 AM   #3
djproch
Thanks, I've watched that video a few times already. Guess I should have realized the two systems are basically identical other than the shape of the drain.
Unread 03-02-2020, 01:09 PM   #4
john619
You want 1/4" per foot for drainage, not a total of 1/4".
Just making sure because that is how I read your thread
john
Unread 03-02-2020, 01:22 PM   #5
Originally Posted by Dave
...putting in a traditional mud pan that will slope from 1.75" at the perimeter down to 1.25" at the drain location to achieve a 1/4" slope.
A drop of only half an inch measured to the far corner from a center drain would indicate an exceptionally small shower footprint, seems to me, Dave. Almost too small to meet code in some jurisdictions. You sure that's what you've got?
Unread 03-02-2020, 01:47 PM   #6
djproch
My shower is basically 46" x 44" with the drain centered, so it is fairly small; I'm pretty sure I did the math correctly.
Edit: Actually looks like I'm a little under 1/4" per foot. I would have to come up ~11/16" from the center of the drain to a height of 1 15/16 (call it 2") not the 1.75" that I said.
Unread 03-02-2020, 01:58 PM   #7
john619
Also keep in mind that the 1/4" per foot of fall is a code minimum.
You may want to have a bit more
john
Unread 03-02-2020, 02:06 PM   #8
That's a decent size shower, Dave.
Keeping in mind that the 1/4-inch per foot slope is the minimium requirement, Dave, I think you're a little short. Half your diagonal measurement would be 2.65 feet by my calculations, which would require drop of a little more than 5/8ths of an inch to meet the absolute minimum. I'd round that off to at least 3/4-inch to be sure I had at least my required slope and in real life I'd make it a tad bit more.
I didn't see John's post in there and I agree with him.
Unread 03-02-2020, 03:05 PM   #9
djproch
Thanks, I'll bump it up to a 3/4" drop from edge to center. In actuality, how noticable would that slope be to a person standing on the floor? I had an old vinyl pan that I ripped out and I would bet money it didn't have that kind of slope to it.
Unread 03-02-2020, 04:45 PM   #10
Your old vinyl pan did not have that same requirement, Steve. Different for pre-manufactured receptor and site-built tiled receptors.
Unread 03-03-2020, 06:56 AM   #11
djproch
Thanks for the advice. Next question, I'm sure I've read this here before but want to make sure that I won't have an issue with embedding the Durock CBU in to the mud pan assuming I am applying the Durock waterproofing membrane on top of everything before tiling?
Unread 03-03-2020, 08:35 AM   #12
Nope, if you're using the Durock membrane on the walls and floor there's no problem embedding the CBU into the mud bed.
Of course, since you're not using a traditional pan liner system there's no reason you have to embed the CBU into the mud bed, since you'll be able to screw the CBU to the studs as low as ya wanna.
Unread 03-03-2020, 08:37 AM   #13
Durock is one cbu that you can bury in the mud. The only one we know of that can't be buried is Hardibacker.
But as long as you're covering it with waterproofing it wouldn't matter anyway.
Durock shower drain in concrete floor question. zeaflal Tile Forum/Advice Board 2 09-07-2018 02:56 PM
Durock shower drain question jls667 Tile Forum/Advice Board 10 02-11-2018 02:13 PM
Durock Shower Drain Me Tile Forum/Advice Board 6 10-26-2017 11:22 AM
is construction adhesive ok under durock? framer Tile Forum/Advice Board 3 05-09-2006 06:58 PM
Hanging durock on 1940s construction JBlaine Tile Forum/Advice Board 9 12-29-2002 11:41 AM
