Unread 11-17-2015, 01:56 PM   #1
The linear drain I've been looking for
Saw this in this month's NTCA newsletter.
Compotite makes the drain I had been thinking about for years. I have a call into the area rep (Dallas) awaiting response.
I'm eager to see one in person
Unread 11-17-2015, 02:32 PM   #2
What part of this are you finding significantly different from other such drains, Paul?
It all sounded pretty similar to other such drains as I read their requirements and could see it working well enough (having also not seen one in person), but when I got to the bottom of the page and saw this part I began to worry:
Using Installation Methods 1 & 2 Together For Added Security.
Unread 11-17-2015, 03:40 PM   #3
MAPEI - Technical Service
Company Representative
Hey Paul, I know you like MAPEI products so I'll also point out that we have a great linear drain system. I'm not sure what features you're looking for that other drains don't have but ours is pretty well thought out. Here is some additional information:
http://www.mapei.com/landingpage/pre...=619&Preview=1
Holden
http://www.mapei.com/US-EN/
Unread 11-17-2015, 04:12 PM   #4
Thanks for the info, this is the link to the installation video of the Shower Perfect system
In the past my favorite has been the Laticrete drain for its sheer simplicity of just 2 pieces. The big drawback is the lack of adjustability to the grate.
Unread 11-17-2015, 04:18 PM   #5
CX, the injection moulded abs construction which makes the base part much cheaper than the welded and shot blast stainless steel bases or the machined plastic.
Unread 11-17-2015, 08:06 PM   #6
Tiger Mountain Tile Inc
What does this drain do that a Noble linear drain doesn't?
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 11-17-2015, 09:26 PM   #7
Far less parts to worry about, but they all do the same thing in the end.
Unread 11-17-2015, 10:52 PM   #8
Ron
Tile Contractor
What I like best about the KerdiLine drain is the frame for the grate. You set it with mortar while you are setting the tile, enabling adjustment and you can make your own weepholes.
Ron
Terra Firma Tile
Ron is offline   Reply With Quote
Unread 11-18-2015, 06:33 AM   #9
HS345
Tile Contractor
HS345's Avatar
Where exactly would you make weepholes on a Kerdiline Drain, and why would you want to? Where is the water going to "weep" to?
The name's Greg
Unread 11-18-2015, 07:23 AM   #10
Ron
Tile Contractor
This is in comparison to an ACO drain. On that one and some others there is a frame attached to the channel body. When you set the drain in mortar it has to be at just the right height and placement for the tile. The frame attached to it which is like a wall around the grate prevents moisture that gets under the tile, between the tile and surface membrane, from getting into the drain... so you'll get grout discolouration around the grate.
With the KerdiLine drain, you set the channel first, flush with the substrate. Then, you can set the separate frame in mortar and adjust the height and a bit of lateral placement. When the frame is set in mortar you can leave some voids here and there so if there is moisture getting in the grout and under the tile it can weep into the drain. Much like a square Kerdi Drain which also has a frame for the grate set in mortar although on those I have never made the weepholes.
Ron
Terra Firma Tile
Unread 11-18-2015, 09:53 PM   #11
PetrH
Ron: I have not heard of anyone setting the Kerdi Line grate assembly in mortar. It's meant to be removable and stays loose. That way the hair catcher can be cleaned out once in a while. I still don't get what you mean by weep holes with either square or linear kerdi drains.
Petr
Unread 11-18-2015, 09:56 PM   #12
PetrH
Mind you I have only ever used the tileable grate assembly, maybe the metal one is different.
Petr
Unread 11-21-2015, 07:42 AM   #13
Ron
Tile Contractor
The grate assembly is in two pieces; the grate and the adjustable frame. That's what I like about Schluter's linear drain. The frame is set in mortar. You can install it before, during or after the tile to get it at just the right height... can even put a small tilt on it if it's against the back wall.
Ron
Terra Firma Tile
linear drain help Levi the Tile Guy Professionals' Hangout 21 10-15-2014 09:47 AM
Linear drain puddling Tile Mechanic Professionals' Hangout 17 02-10-2014 07:44 AM
Tiled Linear Drain TheWire Tile Forum/Advice Board 2 12-07-2012 06:39 PM
linear drain preferences pooky Professionals' Hangout 14 07-30-2012 09:17 AM
New shower with linear drain Bronco Guy Tile Forum/Advice Board 4 03-10-2011 03:29 PM
