Unread 02-22-2015, 07:37 PM   #1
What's the name of the floor heating system.....
At last years Coverings there was an under tile floor heating system that was super thin, a grey fabric with no discernible wires. Very thin. Might have been made in Dallas.
Anyone remember the name of that product or the company that makes it ?
Unread 02-22-2015, 08:13 PM   #2
Tiger Mountain Tile Inc
You're not talking about that thin filmy carbon stuff are you? Where the entire thing conducts electricity?
Jim Upton
Curious how the new Delta Cruzer tile saw stacks up against Dewalt? Check out the full review and video on DIYTileGuy
Unread 02-22-2015, 08:27 PM   #3
Yes, its grey thin film I think
Unread 02-22-2015, 08:28 PM   #4
JTile
Southern Delaware Tile Contractor
JTile's Avatar
HiCarbon?
Their main website doesn't want to work for me.
But here is info from distributor or something.
http://www.flooringheat.com/about.html
Justin
Kyle's Tile LLC
Ocean View, Delaware
www.KylesTile.com
JTile is offline   Reply With Quote
Unread 02-22-2015, 08:32 PM   #5
Carbonic heat
Thanks for the missing word 'carbon'
But its limited to 200 sf per zone and this is a 4000 sf job
Do any wired systems (ditra heat) cover over 200sf? The main room of the house is 1700 sf
Unread 02-22-2015, 08:37 PM   #6
Most any floor warming system can be scaled up. A single thermostat is limited on the amount of current it can sync, but using it to drive a relay or relays will work as long as you select one suitable for the load involved. YOu might have issues if there are areas that get a lot of solar verses where you have the floor sensor or you use multiple thermostats.
Unread 02-22-2015, 09:05 PM   #7
eurob
Not...Sure
Paul , I think the Prodesso Heat is out there now .
You can also benefit from Expansion Units for large areas .
Roberto
Unread 02-22-2015, 09:28 PM   #8
Cain
Cain
Is it protecto wraps system?
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 02-22-2015, 10:29 PM   #9
T_Hulse
Tile Contractor
T_Hulse's Avatar
Paul, most of the major cable systems except Schluter have relays available for large areas like Roberto linked, and they all work with DitraHeat mat. Suntouch is my favorite.
Tom Hulse
Visit my web site here
Unread 02-22-2015, 10:34 PM   #10
The site supervisor is a retired engineer. I'm lobbying in the direction of the ditra as we are using some sort of membrane anyway.
Unread 02-23-2015, 05:49 AM   #11
tilemanct
Tile & Stone
Paul
NuHeat wire works great in the Schluter system. In fact, Nuheat was to supply the wire for Schluter but they were too expensive so Schluter went to China to source its wire.
CTEF Certified Installer
Unread 03-03-2015, 02:02 AM   #12
craigg1
George Craig
craigg1's Avatar
Paul
Right - Nuheat Cables OR WarmWire cables work great with Ditra Heat - they are superior to Ditra's native heating cable.
George Craig
Floor Heating Expert/Customer Support
http://www.warmyourfloor.com
craigg1 is offline   Reply With Quote
Unread 03-03-2015, 01:17 PM   #13
T_Hulse
Tile Contractor
T_Hulse's Avatar
Hi George. In what way are the cables different than Schluter's cables?
Tom Hulse
Unread 03-03-2015, 06:40 PM   #14
craigg1
George Craig
craigg1's Avatar
Hi Tom
The most significant differences are:
  1. Warranty: SunTouch and Nuheat offer a 25 year warranty while Schluter only warrantees the DITRA-HEAT Cables for 10.
  2. Cable design: The gauge of the heating elements inside most resistance heating cables varies depending on the size and voltage of the cable. This means that the diameter of most manufacturers’ cables will vary slightly from cable to cable. The DITRA-HEAT Cables, however, are all uniform in size because Schluter increases or decreases the insulation jacketing around the heating elements depending on the gauge of the wires inside. While this makes the cables snap into the membrane a little more snuggly, it also means that some of them have thicker jackets than is necessary.
  3. Variety of spacing: Nuheat and SunTouch’s cable systems have the option of being installed at a 2 pillar spacing in the DITRA-HEAT Membrane. Doing so makes the systems produce 15 watts per a square foot, which is the practical limit for most residential installations of electric radiant floor heat. According to Schluter’s manual, DITRA-HEAT Cables are only recommended to be spaced at 3 pillars. While the standard spacing is sufficient for many projects, having the option to increase the heat output with these otter cable systems when going over a slab or in an especially cold room is definitely a plus.
  4. Thermostats: The thermostats Schluter currently offers with their DITRA-HEAT systems are limited to 82 degrees, while SunTouch and Nuheat’s thermostats have a broader range that allows customers to raise the temperature past that for tile and stone floors if they so desire.
George Craig
Unread 03-05-2015, 12:36 PM   #15
spfrancis
Sorry for tugging on an older thread. So I could use NuHeat wire, with the Ditra heat system. Can I also use a different control system. I liked the SunTouch View control panel. My wife really liked the touch screen control panel, but liked to use the Ditra heat base.
Sony
Sony
spfrancis is offline   Reply With Quote
in-floor / under-floor electric heating - best system? schmoggles Tile Forum/Advice Board 53 11-26-2013 11:11 PM
Need help with hydronic heating system Bodie Powers The Mud Box 9 11-15-2013 10:10 AM
Does anyone here have a ductless heating and air system? leenabug The Mud Box 12 07-27-2013 09:15 PM
Kerdi System / Radiant Heating kjblex Tile Forum/Advice Board 9 10-07-2009 09:20 PM
Tile atop radiant heating system Mavis Bensch Tile Forum/Advice Board 2 08-17-2009 09:27 PM
