Unread 11-09-2014, 05:08 PM   #1
self leveler as a wear surface
Does anyone know of a cementitious self leveler that can be used as a wear surface? Both over wood framing and SOG.
I tries a web search but......
Unread 11-09-2014, 05:14 PM   #2
lou432
Tile Man -- Southern New Hampsire
lou432's Avatar
Paul,
Could be wrong but I think Ardex has a system ??
Louis
White sand+ blue water .
Find the grace in things that you can`t change, and help some body if you can!
"Van Zant"
I`d rather be on my Harley thinking about God than in Church thinking about my Harley .
My Tile Work Pictures
lou432 is offline   Reply With Quote
Unread 11-09-2014, 05:38 PM   #3
K_Tile
Member of Million SF Club!!
Ardex K500 and k301
Unread 11-09-2014, 06:44 PM   #4
Check MAPEI, Paul. I'm thinking they have some sort of topping material, but I'm not sure that it's self leveling.
Unread 11-09-2014, 07:40 PM   #5
Thanks guys, any other suggestions ?
Unread 11-09-2014, 07:48 PM   #6
I think CX may have nailed it with this product.
A phone call to Mapei is in order.
Unread 11-09-2014, 07:51 PM   #7
Arizona Floors
ReTile
Arizona Floors's Avatar
I don't know if you can use it specifically as a wear surface, but it's polishable.
http://www.ctscement.com/rapid-set-tru-self-leveling/
Arizona Floors is offline   Reply With Quote
Unread 11-10-2014, 01:25 PM   #8
MAPEI - Technical Service
Company Representative
Paul, CX is right on the money with his recommendation. Ultratop PC is designed as a leveler that can be the finished surface, either with or without polishing. I'll PM you our sales rep's phone number for your area. Because it's a relatively short shelf life, it will have to be ordered in.
Holden
http://www.mapei.com/US-EN/
Unread 11-10-2014, 05:13 PM   #9
K_Tile
Kevin is right on the money, also Where is my Ardex rep for back up?
K301 is also an exterior wear leveler that is hard as nails
Unread 11-10-2014, 06:48 PM   #10
The SOG shouldn't be much a problem to prep, its the second floor, as this is a condo type of structure with some sort of cementitious layer over plywood between the upper floors.
Covering everything is some high lippage slate with a shine that will blind your eyes.
Unread 12-02-2014, 11:07 PM   #11
Jim Cordes
Paul are you describing gypcrete by chance? its used on plywood in condos to get fire ratings and such...if so you might want to make sure the topping product is compatable. Ardex does make a product (sry I forget the exact german VX-4 rocket sounding name it has but I think its something 4) its used to repair gypcrete.
Im guessing you may have to treat the gypcrete(if thats what you have) first before applying a topping..make sure to check
Jim
Jim Cordes is offline   Reply With Quote
Unread 12-02-2014, 11:12 PM   #12
I elected to pass on this particular job. Got too many other things to do to occupy my time.
Unread 12-03-2014, 08:28 PM   #13
K_Tile
Ardex GS-4
Unread 12-03-2014, 08:50 PM   #14
CASAVANT TILE
I believe any of the drytek products from Laticrete can be used as a finished surface as well.
Eric Tetreault
Casavant Tile
NTCA 5 Star Contractor
http://casavanttile.com
CASAVANT TILE is offline   Reply With Quote
Unread 12-03-2014, 11:48 PM   #15
T_Hulse
Tile Contractor
T_Hulse's Avatar
Ardex has products for SOG, but none at all that can be used as a wear surface anywhere over a wood-framed floor.
Tom Hulse
Visit my web site here
Latisil tube-tops. (not women's wear from the 70's) Topspin Professionals' Hangout 8 11-08-2011 10:16 PM
The Next Time You Water The Lawn Wear A.... ob1kanobee The Mud Box 24 12-23-2010 04:15 AM
Why you should always wear goggles, And maybe a cup as well. Square pusher Professionals' Hangout 19 06-08-2009 06:58 PM
re: wet saw blade wear gramps Tile Forum/Advice Board 2 02-03-2009 01:26 AM
Bactira fighting soap, and grout wear woodie Professionals' Hangout 1 07-18-2008 03:45 PM
