Unread 11-27-2013, 07:58 AM   #1
erniepaul21
Dimensional tiles over drywall fireplace facade
Hello,
I am considering taking on a fireplace facade remodel project. I would like to mount 1' x 3' ceramic tiles over drywall with thin set on a fireplace facade that is 6' x 10'.
Do I need to install 1/4" concrete mesh board first for stability or can I simply mount the tiles over the drywall? I have tiled plenty of backslashes with a drywall substrate but was curious if overall stability and temperature might be an issue with the bonding of the tile.
Any tips would be greatly appreciated.
paul
erniepaul21 is offline   Reply With Quote
Unread 11-27-2013, 08:48 AM   #2
Paul,
If the drywall has been there a while and not lit on fire yet, I'd think its a pretty good indication you can tile to the drywall.
Got pics?
is this a remodel? the framing new?
Unread 11-27-2013, 08:50 AM   #3
Welcome, Paul.
If your wall framing is adequate, your drywall properly attached and sufficiently flat, I see no reason you can't bond your tiles directly to the surface.
If you have a heat issue, you can't have the drywall there at all, so I'm not sure what your concern would be there. You have specific concerns with this fireplace installation?
Unread 11-27-2013, 09:23 AM   #4
Bodie Powers
Retired cabinet maker/remodeler
If the drywall is painted I would first scuff it up with some coarse sandpaper.
Bodie
Bodie Powers is offline   Reply With Quote
Brick facade of fireplace not attached to wall.. mkperez Tile Forum/Advice Board 5 11-08-2013 03:37 PM
Dimensional Tile Backsplash Novablue Tile Forum/Advice Board 6 10-12-2013 10:38 AM
Need advice for tiling fireplace facade gsm113 Tile Forum/Advice Board 3 01-21-2011 09:01 AM
setting three dimensional found objects leeanne Tile Forum/Advice Board 6 10-13-2010 06:47 PM
dimensional stone on wood tread fredm Tile Forum/Advice Board 5 05-24-2009 10:35 AM
