Unread 10-08-2013, 08:04 PM   #1
Novablue
Dimensional Tile Backsplash
We are looking a using a 3D tile Porcelanosa Ona Blanco as a backsplash. Does anyone have any experience with mounting a switchplate to this type of textured 3D tile? Do you use grout to fill the gaps or do you try to grind the tile flat around the switch plate or grind a groove or ???
My installer was stumped. He had only used this for bathroom walls.
Thanks.
Rob
Novablue is offline   Reply With Quote
Unread 10-08-2013, 09:21 PM   #2
Rob,
Welcome to the forum.
Any chance the outlets can be moved to the underside of the cabinets?
Unread 10-08-2013, 09:44 PM   #3
tilejoe
tilejoe's Avatar
Those kinds of tiles really cause problems with outlets...
Like Paul said. Or is there some kind of tile that matches without the relief?
You can run a band of something else where the outlets go?
An accent tile you can line around the outlets?
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 10-09-2013, 06:26 AM   #4
Novablue
Maybe if I turned the outlets 90 degrees and ran a band around the top of the granite then? Thanks.
I was also thinking about using a coping saw on the switchplate cover to get it to settle down on the 3D pattern.
Rob
Unread 10-10-2013, 08:59 AM   #5
That is going to be a challenge. What is the depth variation of the tile face?
I don't think grouting around the covers is going to look good and will likely crack as the outlet and cover flex when you insert or remove plugs. I'd rather use a color matched caulk in that case. IMO, I want the outlet/switches/plates to blend in to the tile as much as possible to be less visible so doing any kind of band around them would defeat that.
If you can find covers that have a bit of a lip that is proud of the rest of the back of it you might be able to sand it down enough - kinda like scribing it, but depends on the depth variation of the tile.
Placing the outlets and switches into the bottom of the upper cabinets would be the way to go. Be sure to check you local electrical codes.
Unread 10-10-2013, 10:27 AM   #6
chuck stevenson
I have used box extenders when necessary.
http://www.aifittings.com/catalog/mi...-extender/BES1
Sometimes a plaster ring is added first to get to where I need to be.
These might work Rob.
Chuck
No curb, walk-in shower.
Unread 10-12-2013, 10:38 AM   #7
Novablue
Just received these pictures from the manufacturer. Apparently they just install the plates that can raise up to 1/16 inch. It is up to the client if they want to grout or not.
Rob
setting three dimensional found objects leeanne Tile Forum/Advice Board 6 10-13-2010 06:47 PM
Outdoor gas grill tile backsplash heatshield tile surround po1973 Tile Forum/Advice Board 2 08-16-2010 10:17 PM
Best way to prep backsplash for glass tile after removing existing tile bjanecka Tile Forum/Advice Board 8 10-25-2009 06:58 PM
dimensional stone on wood tread fredm Tile Forum/Advice Board 5 05-24-2009 10:35 AM
Tile backsplash above laminate backsplash Robertb Tile Forum/Advice Board 4 06-23-2007 07:12 PM
