Unread 09-26-2022, 10:46 PM   #1
Forrest
Ditra heat spacing between sheets
I'm installing Ditra heat in my bathroom, using a 26.7 sqft 120 cable, so its a relatively small space.
I just set my membrane sheets, and my lugs are pretty close to perfectly in line sheet to sheet which I am happy with. However in between a few sheets I have some small gaps, maybe an 1/8th in at the largest.
Is this detrimental to my install? All I saw on the install page from Shluter was to "abut the sheets" or something along the like. I tried my best but with some Thinset oozing out in between sheets I must have missed some details.
I'm not shooting for perfect waterproofing, but just want to make sure the wire will function properly.
Thanks for the help, having fun working through my first bathroom remodel!
Forrest
Forrest is offline   Reply With Quote
Unread 09-27-2022, 05:40 AM   #2
pls
Gaps are not a problem at all. If you want the seems waterproof you will need to go over them with kerdi band after the cable is installed.
Phil
pls is offline   Reply With Quote
Unread 09-27-2022, 11:35 AM   #3
Dan Marvin
Company Rep
As Phil stated, the gaps aren't an issue although I would recommend cleaning out any mortar that has come up beyond Ditra heat. Don't lay cable in the gap itself, make sure it is securely installed between the studs on the sheet. KERDI-BAND at the membrane seams and at the connection to the wall will make the assembly waterproof. Thanks for choosing Schluter.
Dan - Schluter Systems
Dan Marvin is offline   Reply With Quote
Unread 09-27-2022, 12:24 PM   #4
Forrest
Thanks for the reply. Next question -
After cleaning up Thinset, I noticed I have a couple air pockets. Maybe 3 lugs x 2 lugs at the most in 2 or 3 places.
Do I need to cut these out and put in new lug patches? Putting down 12x24 porcelain tiles.
Forrest
Unread 09-27-2022, 12:56 PM   #5
Yes, I would. You want as close to 100% coverage as possible.
Ditra rising in center of sheets hmat5 Tile Forum/Advice Board 6 05-01-2022 12:45 PM
Mixing Ditra Heat & Strata Heat components jutsin Tile Forum/Advice Board 5 01-10-2019 10:19 PM
Ditra Heat Spacing Problem / Question Evanston Tile Forum/Advice Board 5 12-08-2017 07:42 PM
Ditra Heat spacing bacon Tile Forum/Advice Board 9 09-08-2016 11:47 AM
Ditra Heat Comments in Regards to Floor Heat matthewstephanie Tile Forum/Advice Board 9 03-17-2016 07:37 PM
