Unread 03-26-2009, 07:38 AM   #1
dean0
Tile over Tile-Thinset/Mastic question
Hi all,
I will be laying ceramic tile over an existing tiled shower floor, as well as the walls of the shower. The rest of the bathroom will be tiled over new hardibacker.
What type of thinset for the tile over application? Versabond? anythinbg I can get a a big box store?
BTW great site and extremely heloful group of people!
dean0 is offline   Reply With Quote
Unread 03-26-2009, 07:50 AM   #2
Lazarus
Lazarus's Avatar
Versabond is decent thinset. Having said that, we don't like to see showers tiled over. Yes, it might work, but it's not the best way to go. Trying to attach tile to a slippery surface is hit & miss at best. The least would be to scarify or "rough up" the old surface. Too many questions here about your project without knowing more. Got any pictures? Why are you re-tiling rather than tearing it down and doing it properly? Any leaks? How's the plumbing? I'm sure others will chime in here.......
Laz...
Unread 03-26-2009, 07:51 AM   #3
ddmoit
ddmoit's Avatar
Welcome to the forum, Dean.
VersaBond will work, but you have to thoroughly remove soap scum and other residues as well as scuff up the surface of the existing tiles.
Would you mind telling us what you are trying to accomplish?
Dan - a DIYer in SE Tennessee
Unread 03-26-2009, 07:52 AM   #4
Dean, have you checked to see if your shower valve will still work with the increased thickness of your new tiles?
Use Flexbond or Versabond Flex to bond the new tiles to the old ones. Clean the old tile of any oil, soap scum, or anything that may interfere with the thinset bond. Scuff sand the gloss off the tiles, and vacuum up all the dust.
Unread 03-26-2009, 09:01 AM   #5
dean0
wow, thanks for all the responses!.
The color of the tile is what we dislike:
There are no leaks. The floor tiles are not glossy,I'm sure I'll have to do plenty of cleaning to prepare them.
The shower valve: How would I be able to figure out if it'll fit with the tile over.
I appreciate the advice on tear out but i've ruled it out for now.
I knwo it's a tile forum- should I just reglaze!?
Unread 03-26-2009, 04:03 PM   #6
Lazarus
Lazarus's Avatar
That could certainly be an option. Get a couple of quotes!
Laz...
Unread 03-26-2009, 04:32 PM   #7
Old World Tile and Marble
a redo or reglaze but tile over tile in a wet area will have you paying over and over and over did i mention over?
jason
Old World Tile and Marble is offline   Reply With Quote
Unread 03-26-2009, 05:22 PM   #8
Lazarus
Lazarus's Avatar
Just did a re-do on a shower with NO pan....redguard on everything and everything failed. It was a tub conversion, with a 1.5" drain where the tub drain was....carrera marble everywhere and a seat. HO couldn't figgure out why the water was rushing out of both ends and was 2" deep in the shower. Turns out the floor tile was THREE layers deep....needed a telescope to even SEE the drain. As to the thread, the drain WILL be "Deep" in the tile and looks like crap. I strongly encourage you to demo this job and do it right. Trust this; wee will help walk you thru it.
BTW, ripped out the bottom 12" of carrera, installed a proper pan & slope along with the new liner. He's a happy camper!
Laz...
Unread 03-26-2009, 08:55 PM   #9
Oldrem
Oldrem's Avatar
Send a message via Yahoo to Oldrem
Nearly 3 years ago I remodeled my bathroom, but chose not to retile the shower floor. I opted to try a refinishing product. I had to argue with the folks at Menards that YES Rust-Oleum's Tub and Tile Refinishing Kit COULD be tinted as per their website. They finally agreed to do it lol. The prepping of the tile entails doing about everything you are taught NOT to do to tile. 1) Scrub it well with bleach water and rinse. 2) Scour it with Comet cleanser using an abrasive pad and rinse. 3) Scrub it 3 times with Lime Away using an abrasive pad - letting the product sit for 5 minutes between scrubbings / rinse. 4) Sand it with wet/dry sand paper / rinse. 5) Let it dry thoroughly 6) Wipe it down with a tac cloth. I applied 2 coats over 2 days.
To date, it doesn't look any different than it did when I finished it.
Eric
Lifetime DIYer, Cowboy Action shooter, Gun collector
http://www.computer-adventure.com
Oldrem is offline   Reply With Quote
Can you tile over old mastic/thinset? Kitchen redo dianoharra Tile Forum/Advice Board 6 09-27-2008 07:06 PM
Thinset or mastic for porcelain tile gpreissler Tile Forum/Advice Board 8 05-02-2008 12:16 PM
Tile job Do Over: Mastic is out, Thinset In Mr.Magoo Tile Forum/Advice Board 7 10-23-2007 06:16 PM
Thinset vs. Mastic--question Nutmeg06 Tile Forum/Advice Board 11 07-23-2007 08:10 PM
Mastic or Thinset for 16x16 granite tile backsplash aaron_k Tile Forum/Advice Board 5 11-11-2006 12:55 AM
