Unread 01-17-2020, 09:59 PM   #1
Linkjn
Shower to tub project— no grout?
I’m new here (and wish I would have found this place sooner). First kid on the way and we have a contractor doing a shower to tub project in the guest bedroom.
Contractor was instructed to do 1/16 or 1/8 grout on the tile, but it looks like he left no room for grout.... Also does not look like enough space for caulk where the tub meets the tile.
Full disclosure is that I’m a complete amateur— first house and no remodel/tile experience. Got home late from work and thought I would hear from the experts here. Any insight is appreciated. Thank you
Jarrett
Linkjn is offline   Reply With Quote
Unread 01-17-2020, 10:01 PM   #2
Linkjn
Note that there are “spacers” on the left, but none on the right.
Unable to fit a razor blade between some of the tiles on the right....
Jarrett
Unread 01-17-2020, 11:27 PM   #3
Welcome to the forum, Jarrett.
Sorry to hear. It’s a bit tough to see the groutlines in the pics as they aren’t straight-on shots. But from an industry standpoint, the minimum groutline standard is 1/16”. And if you’ve asked for 1/16”-1/8”....not sure why a contractor would not deliver.
In addition, I don’t see the required mesh tape at the horizontal seam of the left ‘wet wall’, nor does it look like there’s any in the vertical corner...So I’ve got an immediate red flag going up.
Which makes me ask the next question of: What material (exactly) is being used to set the tiles? Glass tile is well known to be finicky and not every setting material is appropriate.
I assume you haven’t spoken to the contractor since?
Unread 01-18-2020, 12:56 AM   #4
Welcome, Jarrett.
Originally Posted by Jarrett
...a contractor doing a shower to tub project in the guest bedroom.
Do I understand that to mean there is not a shower associated with that tub surround?
Unread 01-18-2020, 02:33 AM   #5
If there is a shower head, what type of moisture barrier was used behind the tiles?
Unread 01-18-2020, 05:23 AM   #6
WHERE'S THE WATERPROOFING??? As for the lack of gap I would bet the tub isn't level as so few are, but in turn your guy should have shaved some of the bottom row, in his defense glass tile doesn't like to shave but it can be done. I am most concerned about the waterproofing method, cause if there isn't any, that lack of gap is the least of your concerns.
Unread 01-18-2020, 07:27 AM   #7
Linkjn
Thanks for the quick responses. Unfortunately I do not see any waterproofing or membrane being laid down— none in the corners or on the tile backer board.
See below for a picture of the mortar being used.
I
Jarrett
Unread 01-18-2020, 07:29 AM   #8
Linkjn
Here’s another close shot of the backer board, mortar and tile.
Yikes. My guess is that this has to be ripped out and replaced.
Jarrett
Unread 01-18-2020, 07:37 AM   #9
I see the opening at the top of the left wall for the shower head arm.
If you can't even get a razor blade between the tiles, Jarrett, then you'll not be able to get grout between them either. Lots of tile, glass included, have a slight bevel to the sides, but that won't be deep enough to hold the grout.
The lack of water proofing is certainly an issue, any idea/indication that he may have hung plastic sheeting behind the wall board?
Unread 01-18-2020, 08:14 AM   #10
Linkjn
I will ask him if there was any plastic sheeting. He is coming over later this morning.
I just had a brief phone conversation with him, and he is trying to say that Redgard could have been an extra “option”, but not required because the backer board and caulk would be enough of a water barrier. Not the response I was hoping to hear.
Jarrett
Unread 01-18-2020, 08:21 AM   #11
Nor the response you'd want to hear.
While the glass tile is water proof the grout and backer board are not. Caulk is, but is highly dependent on being properly installed to create a seal, and caulk will, eventually, fail.
Afraid you've got your hands full here, Jarrett, sorry about that.
Unread 01-18-2020, 08:25 AM   #12
I believe the first place you'll have problems is in the niche and window. Those horizontal surfaces will catch a lot of water. How are those built, just Hardiboard screwed to the wood framing? By the way, Hardiboard is not waterproof.
Unread 01-18-2020, 08:33 AM   #13
Here's a shower that had cement board behind the tiles with no moisture barrier. Hardi won't stop the water any faster. You can see the black mold in the green board. All the studs on the bottom half of the shower were saturated too. You have a tub which is a little different situation but you still can see what we're talking about. The bathroom door, which is on the far left, would not close due to the swelled studs.
Exterior grout repair project Mr. Nibbles Cleaning, Restoration and Sealing 7 04-23-2010 03:53 PM
shower tile project: caulk or grout first? Bruce K Tile Forum/Advice Board 1 02-22-2006 02:22 PM
Done with project EXCEPT GROUT COLOR PROBLEM taatjben Tile Forum/Advice Board 3 09-21-2004 06:27 PM
First tile project..Grout questions JD Molding Tile Forum/Advice Board 2 02-03-2004 06:21 PM
Re-grout project alibroth Tile Forum/Advice Board 3 12-22-2003 11:39 AM
