Unread 02-24-2008, 06:58 PM   #1
Jemcon
Kerdi over Plaster
I have a bathroom I am going to tile and was wondering if I use thinset to level the plaster can I put Kerdi over it? I figure if I wet the scratch coat on the missing spots so it doesn't suck the water out of the thinset I can skim it.
This is the back wall of the shower. I would like to do the side wall also but I don't know if that's a good idea. The wall with the mixing valve is cement board.
I was wondering what the best way to raise a floor flange under the toilet if I tile over the existing tile. The tile now is a mud floor so it is rock solid.
Thanks, Jeremy
Jeremy
Jemcon is offline   Reply With Quote
Unread 02-24-2008, 07:46 PM   #2
Hi Jeremy. Yes, thinset will stick to plaster then you go go over the thinset with more thinset and Kerdi.
Unread 02-24-2008, 08:38 PM   #3
Jemcon
Thanks Davy, Should I wet the plaster first so it doesn't suck out the moisture.
Jeremy
Unread 02-24-2008, 08:41 PM   #4
You can, won't hurt anything. Thinset will fill voids up to about 1/4 inch thick at one time. Not sure how deep your patches are.
Unread 02-24-2008, 08:46 PM   #5
Jemcon
Is this ok for the side wall too? Any idea for the floor flange? I figure I can mount a repair flange over the old flange to raise it up and use a wax ring with a horn.
Jeremy
Unread 02-24-2008, 08:57 PM   #6
You can use Kerdi over the side wall that has cement board, as well. In fact, without a moisture barrier behind the walls, it would be wise to use the Kerdi for all 3 walls.
As for the closet flange, buy an extender ring(s) like the ones pictured below and use 100% silicone to seal it to the original closet flange. Make sure the old flange is cleaned of wax before sealing the new one down.
Unread 02-24-2008, 09:02 PM   #7
Jemcon
Thanks Tool Guy. The side wall currently has plaster on it. If I need to do cement board I will. The only wall with cement board is the front wall with the shower valve in it.
Thanks again for both of your help.
Jeremy
Unread 02-24-2008, 09:12 PM   #8
tileman2000
New England Tile Man
tileman2000's Avatar
Hi Jeremy,You can leave the plaster as planned.The reason there's a cement board on the pipe wall is there must've been a problem with leaking.So since you're using Kerdi,keep the walls you have.
Michael
Unread 02-24-2008, 09:45 PM   #9
Jemcon
Thumbs up
Thanks Micheal, ALL you guys saved me alot of work. Thanks again to all that helped.
Jeremy
Unread 02-24-2008, 09:58 PM   #10
Jemcon
For Kerdi they say unmodified thinset. I use Versa-bond for normal tiling but that is fortified. Would you recommend Custom blend for Kerdi or is there a better thinset for Kerdi. Thanks
Jeremy
