Unread 09-04-2019, 07:15 PM   #1
Ryanc22
Sealing Brick before grouting —Wait Time
Hi. I recently installed thin brick on a wall and floor and I am now ready to seal and grout. The sealer directions show a dry time of 2-3 hours so I planned on applying the sealer and then begin to grout after that time. After reading online it seems that most people say to wait 24 hours before grouting, but I am
not finding much on this topic. Any advice would be appreciated. I would rather not wait as I have limited time. Thanks!
Ryan
Ryanc22 is offline   Reply With Quote
Unread 09-04-2019, 07:24 PM   #2
For most thinsets, you should wait 24-hours before grouting. If that time has elapsed, go with the instructions on the sealer for the wait after that. You could put the sealer on prior to that initial 24-hours so you could grout after 24.
Unread 09-04-2019, 07:46 PM   #3
What Jim said, Or you could have used speed set and walked on the tiles even sooner.
Unread 09-04-2019, 07:59 PM   #4
You probably want to avoid getting lots of sealer in the gaps where you'll be grouting. See what the instructions say about that, or maybe call the manufacturers involved. Brick has lots of areas for the cement to grow into during curing, so it may not be an issue.
Unread 09-05-2019, 01:24 AM   #5
Ryanc22
Thanks for the replies. The tile has been set for two days so I am not worried about moving on it. I am just wondering if 2-3 hours is enough time for the sealer to do it’s job (completely dry) and not cause any issues while grouting? I plan on sponging it on and will try to avoid getting between the spaces as mentioned above. Also, I am assuming I will need to do 2 coats or more-how long should I wait before I start the 2nd coat since I will be walking over the tile I just sealed?
Ryan
Unread 09-05-2019, 05:18 AM   #6
We have no idea which sealer you plan to use, Ryan. There are many different brands and each brand has several different sealers. The drying times vary so it's usually best to go by the label that's on the particular sealer bottle you plan to use.
Unread 09-05-2019, 06:26 AM   #7
Ryanc22
Sorry, that’s a good point about the brand. The sealer is made by Tilelab—Grout and Tile sealer. I am starting this morning so I plan
on just going by the 2-3 hours recommended on the label and hoping to re-coat when it seems dry enough to walk on.
Ryan
Unread 09-05-2019, 02:58 PM   #8
While there may be exceptions, following the manufacturer's instructions is usually your best guide!
Note that sealers aren't really designed to waterproof things...stuff you spill on them will soak in and stain IF you don't clean up quickly. How quickly will depend on what was spilled, the tile, and the type of sealer used. THey are generally designed to slow the penetration so you have a chance to clean it up, but won't stop it from staining if you don't. When first applied, stuff might bead a bit, but that's not a certainty.
Unread 09-05-2019, 05:42 PM   #9
They do make a grout release that we sometimes use on rough surfaces. I would mix a little grout and test an area. Even with the sealer applied, the grout might want to set too fast. Don't spread much at a time until you get the feel of it.
Unread 09-05-2019, 10:23 PM   #10
Ryanc22
Thanks for all the advice. I finished the wall today and had no issues with the sealer. I did the wall the traditional way and man did it take forever with the grout bag and finishing tool. I am going to try the floor tomorrow with the float and see how that works before going back to the grout bag.
Ryan
Unread 09-06-2019, 04:52 AM   #11
I'd probably do the whole thing with the bag, Ryan. Using the float and sponge may look a little different than the bag and tool.
Depending on the brick, the float may fill the pores of the brick with grout and I'm not sure if it will all clean out. Sounds like you've been able to avoid getting grout on the brick using the bag which should turn out cleaner on the surface.
Can you post a pic when you're done?
Wait time between grouting and 511 impregnator caykroyd Cleaning, Restoration and Sealing 8 09-03-2013 09:42 AM
How much time to wait before grouting Saltillo gatlin Tile Forum/Advice Board 4 05-20-2013 06:10 PM
Wait time for grouting Gordie Tile Forum/Advice Board 5 07-28-2009 11:44 AM
wait time to set toilet after grouting kingsnake Tile Forum/Advice Board 2 06-20-2004 08:21 AM
Wait time for tiling and grouting? RonCox Tile Forum/Advice Board 1 04-15-2004 07:10 PM
