Unread 03-04-2004, 02:07 PM   #1
regas99
Question Handling existing back splash transition
Hi all! Attached is a photo of an existing formica counter top and back splash. The inside corner has a metal transition with 1/4" vertical and 3/16" horizontal exposed. The edging at the top of the back splash sticks out 1/4".
I plan to tile over the counter top, which does have 3/4" plywood backing. What should I do about the back splash?
If I plan to remove it, can I be sure that the corner transition extends behind the back splash instead of under the counter? I don't want to have to remove the formica counter top.
Or should I attach CBU over the back splash to fill in the 1/4" "valley" between metal railings, and tile over everything?
And / or put new transitions over the top of the old ones? Or cover them with grout?
Tom
Tom
regas99 is offline   Reply With Quote
Unread 03-04-2004, 04:37 PM   #2
doitright
doitright's Avatar
Hi Tom, Welcome
Since you're redoing anyway, I would practice taking a piece off, and see how it's all put together. What have you got to loose?
John Koessler
Unread 03-04-2004, 10:50 PM   #3
T_Hulse
Tile Contractor
T_Hulse's Avatar
Hi Tom,
All of the trim is attached to the backplash piece of plam, none of it is attached to the counter. Rip it off!
(be careful of your paint around the splash)
Tom Hulse
Visit my web site here
