Unread 06-20-2014, 07:35 AM   #1
mbruner
New backsplash - how to deal with old damaged laminate backsplash
Hi. I am replacing a laminate counter top + backsplash with a new countertop and would like to do a tile backsplash. I've already got the new countertop measured and set to be installed. I need a bit of advice.
The attached picture is not the greatest but does provide a glimpse of what the area looked like before I began the project. The area in question is behind the old stove and along that wall. The new stove will be a free standing stove.
The previous backsplash is laminate/Formica over plywood. I began removing this backsplash (the first section came off very easily) only to discover that most of it can not be removed without the old adhesive damaging the plywood below.
So now I currently have a backsplash that is 75% laminate and about 25% somewhat damaged plywood. Removing the rest of the laminate is not going to be possible, so I'm debating:
1 cutting out the plywood and replacing it with backerboard, or plywood, then tiling.
2 installing 1/4 backerboard right over top and tiling over that. I'd lose a bit of counter depth but I don't think that would matter too much.
3 adhering some new laminate pieces to level out the places where I've removed the old laminate, then tiling over everything
4 tiling over it as is. Not sure if this is appropriate at all. The surface is not 100% flat at this point. Although the previous laminate was rather thin, portions where laminate has been removed have dried adhesive or gouges in the plywood.
At the moment I am thinking #2 is my best bet. I do not want to reinstall any of the cabinets if I can help it, and #1 seems like too much work to accurately remove the old backsplash. #3 and #4 would save some labor and counter-depth, but I'm not sure it would be appropriate.
Recommendations would be much appreciated!
Thanks, -Mike
mbruner is offline   Reply With Quote
Unread 06-20-2014, 06:27 PM   #2
PC7060
PC7060's Avatar
Hi Mike, welcome to the forum.
Can't tell from the picture where the backslash is located. Is the plywood mounted over drywall on the back wall?
If so I'd strip the laminate off and plywood and then evaluate the condition of the drywall.
Damaged cabinet due to backsplash removal Deb Gray Tile Forum/Advice Board 6 03-28-2011 05:34 PM
Tile over laminate backsplash Bridon Tile Forum/Advice Board 12 12-21-2010 07:54 AM
Tile backsplash above laminate backsplash Robertb Tile Forum/Advice Board 4 06-23-2007 07:12 PM
laminate backsplash removal ninerjim Tile Forum/Advice Board 2 12-02-2006 01:52 PM
Damaged subfloor quickfix and Backsplash question Kevster Tile Forum/Advice Board 2 12-13-2005 05:48 AM
