Unread 12-01-2008, 08:46 PM   #46
once you set the grate/collar & lat ring collar in the thinset, you need
to push the thinset under the grate and then once hard like Brian said it will lock it in.
Unread 12-01-2008, 08:52 PM   #47
morabors
Thanks for the tips
Bob
morabors is offline   Reply With Quote
Unread 12-02-2008, 12:38 AM   #48
Brian in San Diego
Brian in San Diego's Avatar
Vince,
I used Spectralock grout and I grouted all changes of plane. A year and a half later and it is still free of cracks. I say go forth and grout it.
brian
Unread 12-26-2008, 02:40 PM   #49
Supergirl
See one, do one, teach one
Supergirl's Avatar
Wink
Brian- I have heard that since epoxy grout is harder than cement gout, it is more likely to crack in the change of plane...
I read that JB just grouts all those seams, but I am no JB
Does this have anything to do with the Kerdi being underneath, meaning, does it act like an isolation membrane in the change of plane??
'Cause I would love to grout without using silicon, and am grasping for a solid reason to decide this....
Thanks!!!
Sarah
Supergirl is offline   Reply With Quote
Unread 12-27-2008, 12:41 PM   #50
Brian in San Diego
Supergirl,
There were warnings about Spectralock being so strong that tile would break before the grout would crack. Even though I live in an area that can get shaky once in awhile I decided to grout everything and take my chances. I am glad I decided to go that route. I like the way the grout looks and haven't had any problems.
Unread 02-09-2009, 10:24 AM   #51
vfgilber
vfgilber's Avatar
I have a new question. The tiling is all done, but now we have to have the glass installed.
Because of the way things are set up, the door is going to have to hinge off of a 5" wide glass panel at the wall. That 5" panel will be supported by a header bar, and a U-Channel secured to the curb.
The issue is: the curb is Kerdi foam curb. I presume that since the weight of the glass door will be transferred to the fixed panel, that U-Channel needs to be firmly attached to the curb. Can anyone suggest a good way to attach the U-channel? Remember, there's no wood to screw it into.
Would an adhesive like PL be sufficient?
The only other idea I can think of is to drill a hole all the way from the top of the curb right down through to the subfloor and use a LONG threaded rod secured from the basement with a washer and nut.
Vince
Owner of Urbanbiketech.com
Totally unrelated to Tile, but hey, it's my baby.
vfgilber is offline   Reply With Quote
Unread 02-09-2009, 11:58 AM   #52
The Kid
The Kid's Avatar
double face tape and silicone the uchannel, youll be suprised at how strong it will be. Id screw the top chanel into the lid and id also have a uchanel running verticaly on the panel wall. I would also install the uchanells in the same fashion on the buttress panels so you dont go through your kerdi. This is how the glaziers do it and its strong.
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Unread 02-09-2009, 12:28 PM   #53
vfgilber
vfgilber's Avatar
Jeremy - thank you for the response. I have a question concerning one of the terms you mentioned.
What is the "lid"?
Vince
Unread 02-09-2009, 07:15 PM   #54
Supergirl
Supergirl's Avatar
What is your curb topper? tile? stone slab?
I called Schluter with this very question as I plan on using the foam curb as well, and had concerns about screwing into Kerdi on top of the curb!
In the case I discussed with Peter up in Plattsburg, the foam with a distributed weight will be fine on the foam curb, in terms of screwing into the Kerdi, I will have a marble curb that will be cemented to the curb top, and I will backfill the holes with Kerdi Fix (although I will have 1 1/4" thick piece as I understand the screws they use are 3/4" to avoid any possible puncture problem- but that is just 'cause I am paranoid!!) And of course the curb is cemented to the subfloor.
So, you are not necessarily screwing into the foam curb as a means to secure it.
I recommend that you touch base with Schluter to confirm your construction and that it will support your particular situation.
Sarah
Unread 02-09-2009, 07:25 PM   #55
The Kid
The Kid's Avatar
lid=ceiling
Jeremy
Unread 02-10-2009, 10:00 PM   #56
vfgilber
vfgilber's Avatar
I just thought I'd post some pictures (before the glass has been installed)
Vince
Unread 02-10-2009, 10:03 PM   #57
The Kid
The Kid's Avatar
vince, thats looks great. good job man.
Jeremy
Unread 02-10-2009, 10:06 PM   #58
vfgilber
vfgilber's Avatar
more photos (please excuse the cat)
Vince
Unread 02-10-2009, 11:20 PM   #59
Brian in San Diego
Vince,
Congratulations, my friend! You have done a superb job of planning and execution. It looks great!
Unread 02-11-2009, 08:07 AM   #60
Supergirl
Supergirl's Avatar
That looks really nice!
Sarah
