Old 10-11-2018, 11:33 PM   #1
DJI Services
Leveler as Tile Substrate
After many years 15 years of using durock, wonderboard, permabase, and hardi, we are considering a "new" method.
We do a lot of bathrooms. We do a lot of 12x24, 8x36, and etc large format tile. When the subfloor is sound 3/4" plywood with 16 OC joists, we are thinking of applying a synthetic mesh to sub floor and pouring a leveling compound over the entire surface to a minimum depth of 1/4" to achieve a perfectly flat and level substrate in which to set larger format tile...in lieu of a screwed and mortared substrate.
Anyone doing this, have done this, etc? Thoughts and recommendations welcome.
DJI Services is offline   Reply With Quote
Old 10-11-2018, 11:51 PM   #2
Welcome to the forum, Dave.
While I haven’t used it, there’s been a fair amount of talk about Ardex Liquid Backerboard that piques my interest...and it doesn’t require mesh.
Help an awesome summer camp finish their cabin after 10 years in the making. They are only $75,000 away.
Old 10-12-2018, 05:20 AM   #3
CaliGrown
CaliGrown's Avatar
Yes!!! I hardly get to float a floor with deck mud because of height restrictions, this is the next best thing to mud floors. My uncle taught me his self leveling method for wood floors which stands on its own (even over wood plank subfloors). Caulk all finestrations, joints, cracks and seams anything that poses a leak, and then prime the floor. Then take 2.5# diamond lath and nail it down with roofing nails, put down another row of lath down with the sheets oriented perpendicular to the first row. Put any temporary barriers in place for registers, doorways, waste/water lines. Pour your favorite leveler out, any leaks dash out some dry powder to stop them. The two rows of lath stack out to about 3/8”. This makes for a solid floor and a great substrate, it’s not deck mud but it’s not that bad either.
El niño, Chris
Old 10-12-2018, 10:22 AM   #4
Lou_MA
+1 for Ardex liquid backer board
Lou
Old 10-12-2018, 01:17 PM   #5
MAPEI - Technical Service
Company Representative
As Gauged Porcelain Panels have become more popular and tile has grown in general, we have seen many installers making the switch the levelers in place of other substrates. We have been highlighting surface prep in our webinars and educational events for tile installers. I would be careful about levelers that state you can use them without primers, a good primer will pay for itself the first time you avoid a callback for a hollow floor. Better yet would be to use lath. We have a product called Mapelath designed specifically for tile installations with leveler like our Novoplan Easy. Hit up your MAPEI sales rep for more info.
Holden
http://www.mapei.com/US-EN/
MAPEI - Technical Service is online now   Reply With Quote
Old 10-12-2018, 01:51 PM   #6
I've used Liquid BackerBoard on two of my properties with success.
I've not used the Mapei products yet.
Old 10-13-2018, 06:43 AM   #7
roughrider
So this is basically self leveling compound correct,or is it something else ?
Chris
roughrider is offline   Reply With Quote
Old 10-16-2018, 10:47 AM   #8
Mr_Stop
Home Remodeler
Another vote for the Ardex Liquid Backerboard. It is a self leveler that doesn't require lath reinforcement. I have used it a couple of times where I don't have enough room for metal lath required for traditional SLC's as it flows down to about 1/8" or so. The Ardex requires a primer and seems to bond extremely well to plywood. Note, no matter how well you think it is sealed, there will probably still be a leak somewhere.
I still use Ditra to bring up the floor to the final proper height to match the existing floor. Ditra is a bit more economical than Ardex Liquid Backerboard. Also, I feel Ditra gives me some insurance against cracking.
Brad
Follow me on Instagram
Mr_Stop is offline   Reply With Quote
Old 10-19-2018, 06:54 PM   #9
Tiger Mountain Tile Inc
tile lackey
Custom has a new product called WSF which is similar to LBB but it's a 1/4 inch minimum. I haven't tried it though.
One thing about self-levelers: a perfectly flat floor sounds good but it still takes a lot of prep and practice. They are easy to screw up if everything isn't done right. Ask me how I know
Jim Upton
DIYTileGuy
Old 10-31-2018, 07:54 AM   #10
K_Tile
Member of Million SF Club!!
Custom WSF is an excellent product @ half the cost of Liquidbacker in my area. I have no complaints on usage.
Old 10-31-2018, 08:18 AM   #11
tilemanct
Tile & Stone
Use The Ardex LBB with Flextherms Snap system for electric radiant heat. Love the stuff. Great for mosaic work with heat.
CTEF Certified Installer
Armstrong Alterna Vinyl Tile and Embossing Leveler JTile The Mud Box 1 06-12-2013 06:17 PM
reinstalling tile over old mortar--floor leveler or skim coating? confusedbymany Tile Forum/Advice Board 12 10-14-2009 09:57 AM
Self Leveler over Ceramic Tile rodss67 Tile Forum/Advice Board 3 03-03-2009 06:14 AM
Substrate for Tile Hoffa29 Tile Forum/Advice Board 1 07-07-2008 06:09 PM
tile substrate fmatasci Tile Forum/Advice Board 7 04-21-2002 05:38 PM
