Unread 12-03-2009, 08:28 PM   #1
jimbo22s
White haze on grout
Can I use a vinegar mixture to remove the white haze I have on the grout from having applied too much sealer? Or is there something better to use? It has tried for a couple of days.
Thank you.
Jimbo
jimbo22s is offline   Reply With Quote
Unread 12-03-2009, 08:45 PM   #2
Jason_Butler
Tile Setter
Dunno what sealer you used but most of them will re-emulsify if you apply a little more sealer. Once it's loose, wipe off the excess.
What sealer did you use?
Jason
Unread 12-03-2009, 11:17 PM   #3
MNTileGuy
Central Texas Tile Guy
Try what Jason suggested first. Just make sure the second time around you thouroughly wipe off the excess on the tile.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 12-04-2009, 05:16 AM   #4
scott anthony
Tile Man -- Central Florida
scott anthony's Avatar
If that does not work, I have use with good results a product called Klenz-all. I think it's a Mapei product. You will not find it everywhere so you will have do a product search when and if. This will strip the sealer completely.
Scott
scott anthony is offline   Reply With Quote
Unread 12-04-2009, 01:11 PM   #5
jimbo22s
Thank you for the replies.
The haze did not lift when I reapplied the sealer and wiped it up. I will try it again and then try the product recommended above if necessary.
Will the haze fade over time from normal wear?
I used Grout Guard from TEC.
Jimbo
Unread 12-04-2009, 02:22 PM   #6
Davestone
Florida Tile & Stone Man
Typically the sealer will grab onto grout and be hard to remove as suggested.It will probably need to be stripped,my guess is too much sealer was used and dried without soaking in.
http://Davestonestile.com
Unread 12-05-2009, 01:32 AM   #7
doitright
doitright's Avatar
Hi Jimbo, Welcome!
It's important to know what sealer you actually used. Based on my experience it sounds like you used a water based sealer. I'm familiar with one brand that this is a common issue.
Now it has probably totally cured. The KlenzAll product mentioned above is manufactured by Dupont Stone Tech. It is a high alkaline that I doubt will resolve your problem.
You may want to start with Aqua Mix's Coating & Sealer remover.
Please get back to us with more details.
John Koessler
Unread 12-05-2009, 09:27 AM   #8
GeorgeT
StoneTech Rep
Send a message via ICQ to GeorgeT
KlenzAll is one of the things we ask people to try when there is a waterbased sealer residue problem. Depending on the type of tile, an acidic cleaning, as if trying to remove grout haze, could also be effective.
Much depends on technique. Let the products soak for a few minutes. Most of the time this means keeping 'em moving with a brush. Then a good scrub and rinse....
George T. O'Regan
Technical Services
DuPont StoneTech Professional
http://www.stonetechpro.com/
GeorgeT is offline   Reply With Quote
Unread 12-05-2009, 09:35 AM   #9
We were about to send out a search party for you, George.
Unread 12-05-2009, 09:36 AM   #10
doitright
doitright's Avatar
Hi George
What ratio is recommended for KlenzAll in this application? How long can a WB sealer product cure before this method becomes ineffective?
Same questions for Restore.
I'm not as familiar with your WB products and solutions as the SB ones. Thanks for your input!
John Koessler
Unread 12-06-2009, 10:28 AM   #11
GeorgeT
StoneTech Rep
John -
Alkaline cleaners like KlenzAll as well as acidic cleaners like Restore can break the bond of certain active ingredients found in waterbased sealers. Standard dilutions (1:4) are the place to start. I would not go much stronger than 1:2.
One of the keys to effective residue removal is dwell time. The cleaning liquid needs to be given time to attack the sealer bond. Start at 4-6 minutes for either solution. With the alkaline KlenzAll the dwell time can be extended up to 15 minutes or longer. An acid should be vacuumed up or refreshed every 6-10... not much different than regular cleaning with these products. Agitation is important but not always heavy scrubbing.
Solutions can be made stronger but that does not always make the process faster...sometimes it just requires perseverance....
Also, this process does not work with silicone sealers very effectively.
George T. O'Regan
Technical Services
Unread 12-06-2009, 10:29 AM   #12
GeorgeT
StoneTech Rep
cx -
I was kidnapped by pirates, but I managed to escape using tricks I learned from watching Jack Sparrow.... coconuts, rum bottles, turtles.....
George T. O'Regan
Technical Services
Unread 12-06-2009, 11:08 AM   #13
No matter what brutal devices you had to employ, George, we're just glad you made good your escape and returned to help our visitors.
Unread 12-06-2009, 06:35 PM   #14
doitright
doitright's Avatar
Hi George
Thanks for sharing that important info. It's good to know I have your chemicals on my vehicle that can do more than I thought. I'm aware that stronger solutions aren't necessarily the better route to take.
John Koessler
Unread 12-06-2009, 11:19 PM   #15
From filming winders
We sometimes employ a little trick to keep wall surfaces wet longer so chemicals can take time to react before they run down the wall, or evaporate.
You can coat the wall with the chemical as usual, then right away place on a sheet of plastic film. The plastic will cling to the wall, keeping it from drying out and extending the working time. If you need to add more chemical, peel back the very top and spritz some more in.
White haze - what did I do wrong? johnvh Tile Forum/Advice Board 5 03-01-2008 06:50 PM
White Grout Haze sbenton Tile Forum/Advice Board 15 09-12-2007 05:25 AM
White tile Brown Grout - Haze and grout question Birmingham Boys Tile Forum/Advice Board 7 05-02-2006 05:20 PM
White Haze on tile and grout... HELP Rockzulu Cleaning, Restoration and Sealing 9 02-02-2006 09:46 AM
White Tile & White Grout - No longer White trouper Tile Forum/Advice Board 2 10-16-2003 04:24 PM
