Unread 01-12-2013, 07:45 AM   #1
TammyJh
White haze on grout after sealing
I sealed my grout lines last night after letting the grout dry for 3 days and in areas there is this white chalky look in some areas and the grout looks a lighter color. What did I do wrong when I sealed.
Tammy
TammyJh is offline   Reply With Quote
Unread 01-12-2013, 07:55 AM   #2
Lump
Lump's Avatar
What is the name of sealer used?
Brad L. Lenz
NTCA Proud Member
Unread 01-12-2013, 09:12 AM   #3
Davestone
Florida Tile & Stone Man
You let too much sealer on the grout and it dries to a haze.You may need to use some Pine Sol and a brush to get off the excess.Then rinse,don't let it dwell too long as it may remove most of the Absorbed sealer.
http://Davestonestile.com
Unread 01-12-2013, 10:49 AM   #4
TammyJh
Surface grad is the sealer. On the pine sol. Is that diluted or straight
Tammy
Unread 01-12-2013, 10:50 AM   #5
TammyJh
Sorry surface gard is the brand name of the sealer
Tammy
Unread 01-14-2013, 04:47 PM   #6
obsia
Tammy,
I agree with Dave - it is excess sealer. Call the manufacturer to find out how you can remove it or use Dave's method.
Grishma
Obsia - Manufacturer of Permeators.
We are an R&D based company that focuses on eliminating the causes of staining, weathering and issues we run into with stone and concrete surfaces.
Instead of making the stone only resistant by just filling in the pores - we eliminate the porosity, decrease negative effects of mineral impurities and structural deformities.
We don't believe in masking the problems, we believe in addressing the source and causes of such problems.
www.obsia.com
obsia is offline   Reply With Quote
Unread 01-14-2013, 05:43 PM   #7
doitright
doitright's Avatar
Hi Tammy, Welcome!
I third the motion. Very common issue with over application of water based sealers.
I've never tried the Pine Sol. I always go straight to the manufacturer technical assistance and see what they recommend.
John Koessler
white haze on tan grout emaxxman Cleaning, Restoration and Sealing 21 05-05-2014 06:24 PM
Dark Grout White Haze JoanieBob Tile Forum/Advice Board 3 08-29-2011 10:22 AM
White haze on grout jimbo22s Cleaning, Restoration and Sealing 16 12-07-2009 11:04 PM
White Grout Haze sbenton Tile Forum/Advice Board 15 09-12-2007 05:25 AM
White Haze on tile and grout... HELP Rockzulu Cleaning, Restoration and Sealing 9 02-02-2006 09:46 AM
