Unread 04-26-2021, 11:53 AM   #1
KevMatt
Kerdi Board to drywall transition question
I'm installing the Schluter system into a small stand up shower and, given the age of the house, it's no surprise that the room itself is not square. The only way it seems that I am able to get the shower itself square is to have the kerdi-board sticking out the full 1/2 inch width of the board past the drywall next to it. I don't want tiling to be a total nightmare. Any suggestions about the cleanest way to do this?
KevMatt is offline   Reply With Quote
Unread 04-26-2021, 01:47 PM   #2
BIGPHIL
BIGPHIL's Avatar
Welcome to the forum, Kevin! Well...you could do any number of things there, some of it dependant on your tile and the available trim pieces in the line. A bullnose cap, v cap, a Schluter finec trim with mitered tile edges on both sides. Not sure how well mortar will stick to the foam edge though. If you go that route, I'd perform some tests and see how well the mortar adheres to the foam or even set those side prices to the foam edge with Kerdi fix....or maybe rip some thin pieces of the Kerdi board on a table saw and Kerdi fix those to the foam edge.
Phil
BIGPHIL is offline   Reply With Quote
Unread 04-26-2021, 04:47 PM   #3
RichVT
Vermont Remodeling Contractor
The last time I ran into that situation, I just finished and painted the inside corner and then tiled right to the edge of the outside corner. First picture is rotated - it's the right side of the shower in the second picture. Not really noticeable if you get everything lined up.
Rich
RichVT is offline   Reply With Quote
Unread 04-27-2021, 10:30 AM   #4
jeffnc
It appears to me you simply cut the Kerdi Board too long so it won't fit inside the drywall. What am I missing?
Jeff
jeffnc is offline   Reply With Quote
Drywall to Kerdi Board Transition NTM5 Tile Forum/Advice Board 6 02-13-2021 08:40 PM
Kerdi Board to Drywall Transition RichieW13 Tile Forum/Advice Board 31 08-23-2019 06:05 PM
Noob...transition from drywall to kerdi board wwsteel7 Tile Forum/Advice Board 22 06-25-2016 11:10 PM
Transition from Kerdi Board and tile to drywall stephen Anderson Tile Forum/Advice Board 5 03-28-2013 09:09 PM
Transition from Cement board to drywall question taherrmann4 Tile Forum/Advice Board 9 03-06-2011 08:28 AM
