Old 02-20-2019, 05:43 PM   #1
roundrightfarm
tiling over a lime plaster (X-Kalibur) wall
I have heard that lime can be difficult to bond to. I want to do a kitchen backsplash over a wall plastered with X-kalibur brand veneer plaster. Do I need any special type of adhesive or will regular modified thinset work well for bonding ceramic tiles to the wall. This is a one-coat veneer plaster over 1/2" plaster blueboard.
Steven
roundrightfarm is offline   Reply With Quote
Old 02-20-2019, 06:08 PM   #2
I've never used that brand but if it's a base coat and finish coat all in one then I think you could tile over it without a problem. I usually want to stick a scrap piece of tile to it and let it set over night to see how it bonds using thinset.
Old 02-20-2019, 06:32 PM   #3
roundrightfarm
X-kalibur can either be used as a finish coat over a base coat or all by itself in a single coat application. It does not have any sand in it like a typical basecoat and therefore is not as strong.
Steven
Old 02-20-2019, 07:33 PM   #4
National Gypsum requires a bonding agent when applying that product over concrete, Steven, so I'd be curious about bonding directly to it with a Portland cement thinset mortar. I think your best bet would be to contact NG in your area. You have no geographic location in your User Profile so I can't guess which area that might be.
Laying tile over lime plaster oldsheep Tile Forum/Advice Board 1 05-18-2017 06:41 AM
Plaster wall? eliniko1 Tile Forum/Advice Board 18 06-29-2013 05:59 PM
Thinset on old lime plaster cg1175 Tile Forum/Advice Board 13 03-10-2013 07:54 AM
Help with plaster wall jheavner Tile Forum/Advice Board 9 11-20-2012 12:40 PM
Wedi as Substrate for Lime-Plaster (Tadelakt finish) shower? SDangerfield Tile Forum/Advice Board 14 05-25-2011 08:05 PM
