Condo Shower Renovation
Ahoy!
This is definitely my first shower renovation, and being that I am in a 30+ year old condo I want to make sure I won't have any problems down the road.
I have the shower area demo'd down to the original mud base and the studs. I plan to extend the mud base out another ~18" to a new curb that I set. This will give it's final dimensions about 3' x 5'.
Questions:
1. Is this the best time to install a seat along the 5' portion of the wall so I can attach it to studs?
My problem: The previous owners installed a jacuzzi tub on top of the shower area and just poured mounds of concrete underneath it to support/level the tub. It was horribly done. The drain is located fairly close to the wall (for the tub) and this limits me from being able to use a standard seat that is built up from the floor.
I assume I need to just use a single piece of stone/material to make the bench. I would like it to be strong enough to support 2 people.
2. What material should I use for the seat? Stone, pressure treated wood, kerdiboard, etc?
3. What adhesive/hardware should I use to attach it to the wall? I will only be able to attach 2 of the 4 sides to the wall.
Sorry if this post is long! I wanted to provide enough detail to give you a basic idea of what I am trying to accomplish.
Please let me know if you need additional info from me. Thank you for all of your time and help!
Frank
