Mike, a simple and effective way to do this is ude a piece of Scluter metal at the edge.you will see a 1/8" wide piece at the edge when it is installed. it protects the tile edge and your feet from sharp edges.Pull the carpet back and pad.Feather out the area with a cement based patching compound for about 30-36" out.after this dries replace your carpet tack strip on top of this feathered out area and restretch the carpet to the tile edge and trim with a sharp carpet knife.Thats it perfect transition.
For cutting off your door,Run Tape over bottom edge, mark where you want to cut it and score it several times with a good sharp utility knife.Set up a fence for your Circular saw and clamp it tight so the blade stays on the outside edge of the score mark.Be sure your blade is very sharp( a new carbide is reccomended here).
Now carefully cut the bottom,peel the tape and reset your door.
